nope was not there, even tried a bunch of shell commands, the windows store literally did not exist on this machine...Settings - Apps - Apps & Features
You should be able to see microsoft store from there and potentially reinstall it?
That must be so disappointingfor you, so sorry to hear thatSo far the new PC is a bit of disappointment not gonna lie.
There is a small cracks on the distribution plate, due to overpressure on the bolts.
There is a small dent on the front panel of the case.
Every single RGB product in this pc is daisy chained together, so cant even set it up separately.
There is no temperature sensor for the liquid at all.
Some of the cable management is questionable at best.
The tubing could have been done a little bit better, instead of having this weird bended tube in two places for no reason.
And now the software issues.
I guess if you wanna done something right, better do it yourself..
Yeah, kinda ruined the excitment. Especially since i spent 5750 euro on this system, i kinda expected a little bit better quality.That must be so disappointingfor you, so sorry to hear that
You can always return it for a refund if you're not happy.Yeah, kinda ruined the excitment. Especially since i spent 5750 euro on this system, i kinda expected a little bit better quality.
i did sent a message regards the distro plate, what is their opinion on it, will see how i proceed with this. It is at the back of the plate, so you cant really see it. If it wont cause issues in future i dont really care that much to go through the hussle of RMA.I would contact customer services about your issues. I would want perfection for the money paid![]()
yeah after waiting over two months and not having other pc anymore, i would rather prevent that for minor complains. If it was not for the damn market situation..You can always return it for a refund if you're not happy.
If the Microsoft store isn’t loading, you won’t have any windows store apps at all.What is up with this windows installation made by pcsi am missing so many basic microsoft apps. Like this pc does not have the basic paint app to even open pictures
You're not the first. I would contact PCS and ask why your Windows install is seemingly screwed.What is up with this windows installation made by pcsi am missing so many basic microsoft apps. Like this pc does not have the basic paint app to even open pictures
It is really odd, all I can think is they’ve borked an SCCM installation package and haven’t noticed, but this has to stopYou're not the first. I would contact PCS and ask why your Windows install is seemingly screwed.
I have reported it to PCS via the Moderator's high bandwidth back channel.It is really odd, all I can think is they’ve borked an SCCM installation package and haven’t noticed, but this has to stop
i did sent a message to the support regards this, as i was asking about the small crack on the distro plate at the back. Will see what they respond, but at least i informed them that their installation seems to be offYou're not the first. I would contact PCS and ask why your Windows install is seemingly screwed.
i did order with windows, i did use my own Microsoft account that had license attached i guess? since nowadays it seems to be like that.If the Microsoft store isn’t loading, you won’t have any windows store apps at all.
Did you order with windows? Did you log in with a Microsoft account that had a license attached?
I think there is a common issue here. Both yourself and the other user (different thread) with the same problem have logged in to a Windows system activated by an OEM key, with a userid associated with a different Windows license. I'm wondering whether this is a factor?i did order with windows, i did use my own Microsoft account that had license attached i guess? since nowadays it seems to be like that.
Either way, the Microsoft store literally did not exist in the installation. No PowerShell commands worked etc. Had to go and download the installation package for Microsoft apps to get it back.
But as you said, since the store was not loading, no store apps really loaded and installed at the beginning of the the fresh installation setup.
So now it is not really a problem, just inconvenience, but i can just go to the store and download what i need.
it could be, but no one can expect me to create a new microsoft account right?I think there is a common issue here. Both yourself and the other user (different thread) with the same problem have logged in to a Windows system activated by an OEM key, with a userid associated with a different Windows license. I'm wondering whether this is a factor?
