Organground
Hi, when I got my PC I specified two 1TB hard drives in RAID0 configuration. I'm running a special software application that on startup requires reading from the harddisk to RAM of vast amounts of data so I needed to optimise read times and couldn't afford two), let alone one, SSDs. Read times were fantastic. Then I got nervous about data loss and so reinstalled everything, this time in RAID1. Result - the software has slowed down and loads at about a third of the RAID0 speed which is unacceptable.
So what I'm thinking is, ideally without having to reinstall Windows, and using just the two 7200rpm hard disks that as I say are presently configured as one 1TB RAID1 drive, can I
(1) partition the existing 1TB C drive into say an 800GB C drive and a 200GB D drive, and then
(2) convert the 200GB D drive (which will be mirrored across the two physical hard drives) into a 400GB RAID0 drive?
That way I could put the temporary files that need loading onto the 400GB RAID0 D-drive whilst benefiting from the stability and redundancy of having all critical files on the 800GB RAID1 C-drive.
Is this possible? Has anyone ever tried it? I should add that I have installed the Intel Rapid Storage Technology program if that makes any difference to its "do-ability".
