Hello all,
I am starting to slowly upgrade my PC Specialist rig which has faithfully served me well for 4.5 years without issue..
Currently, my GPU is still performing well enough although time waits for no man or rig and I do think it's one of the most important issues to address, the problem I have or potentially might have is the CPU bottle-necking the card and so preventing it from performing proprely or as it was intended.
my current build is:
Processor (CPU) Intel® Core™i5 Quad Core Processor i5-4690 (3.5GHz) 6MB Cache
Motherboard ASUS® Z97M-PLUS: m-ATX, USB3.0, SATA 6.0, XFIRE
Memory (RAM) 8GB KINGSTON HYPER-X BEAST DUAL-DDR3 2133MHz X.M.P (1 x 8GB)
Graphics Card 4GB NVIDIA GEFORCE GTX 770 - 2 DVI, HDMI, DP - 3D Vision Ready
Monitor Qnix 2710 picture perfect.
Case CORSAIR 230T COMPACT GAMING CASE
Card which after some reading is best bang for buck currently I intend on changing to is the Zotac GeForce GTX 1070 Ti Mini 8 GB. my budget is £400.00, less if possible.
Hopefully some well versed individuals here will either confirm or allay my fears.
i should add that PC Partpicker has already shown there are no incompatibilities so Mobo, power and case should be ok, it's just will i get the best out of the card using my current CPU?
feel free to chip in thoughts, experiences etc, all welcome.
thanks for reading this and hopefully you can help me
Best,
Allan.
Best,
Allan.
