minecraft
would this be good for minecraft with mods with no lag
STYLISH PIANO BLACK ENIGMA MICRO-ATX CASE + 2 FRONT USB
AMD A10-6800K Quad Core APU (4.4GHz) & Radeon™ HD 8670D Graphics
ASUS® A88XM-PLUS: (M-ATX, DDR3, USB 3.0, 6Gb/s)
8GB KINGSTON HYPERX BEAST DUAL-DDR3 2400MHz X.M.P (2 x 4GB KIT)
2GB NVIDIA GEFORCE GTX 750 Ti - DVI, mHDMI, VGA - 3D Vision Ready
STANDARD AMD CPU COOLER
Monitor
BENQ GL2250 21.5" LED - 1920 x 1080, 5MS, D-SUB, DVI-D (£89)
CM Storm Devastator Keyboard and Mouse (£29)
FAST TRACK 5 WORKING DAY DISPATCH (£39)
Price: £750.00 including VAT and delivery.
Boozad
I wouldn't get the HyperX Beast memory you'll get no benefit. Go for the HyperX Genesis instead. I'd look at an FX CPU as well as there's no point getting an APU if you're buying a dedicated GPU.
bigben
Master Poster
This.
I would also get a better case and a caviar black HDD
Cadwah
Rising Star
What will you be using the PC for? if it is for gaming then something like this:
COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE
AMD FX-6300 Six Core CPU (3.50GHz/8MB CACHE/AM3+)
Gigabyte 970A-DS3P AM3+ (ATX, DDR3, USB 3.0, 6Gb/s)
2GB AMD RADEON™ R9 270X - DVI, HDMI, DP - DX® 11, Eyefinity 4 Capable
500GB WD CAVIAR BLACK WD5003AZEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
Monitor
AOC 21.5" WIDESCREEN LED TFT - 1920 x 1080, 5MS, D-Sub, DVI-D (£85)
Price: £733.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/amd-bulldozer-top-spec-pc/wbkhjAvjbg/
Try to stick to one thread, you opened a few and it was for the same thing. For £730 I get the following:
CORSAIR CARBIDE SERIES™ 200R COMPACT GAMING CASE
ASUS® M5A97 LE R2.0 (DDR3, USB3.0, 6Gb/s)
4GB KINGSTON DUAL-DDR3 1600MHz (1 x 4GB)
Monitor
Price: £726.00 including VAT and delivery.
Unique URL to re-configure: http://www.pcspecialist.co.uk/quotes/amd-bulldozer-top-spec-pc/FyzX3AGJM9/
what about this
Monitor
4gb of ram???
I would suggest doing more research on the spec you require. 4gb ram is enough for gaming and you can easily add more in the future. You can either get 8gb ram and downgrade the gpu which is not ideal for gaming or stick with 4gb and keep a better gpu for gaming.
ok wat about this
one Case
Monitor
you need a better case, the one you selected is not suitable for a gaming rig. You won't get any improvement gaming wise with 2400mhz, 1600mhz is good enough.
last post how is this
for games like borderlands, minecraft(with mods) and bf4
Monitor
mantadog
Superhero Level Poster
please stick to one thread, this is your 3rd in 2 days on exactly the same subject. Posting multiple times just means people have to answer the same questions in multiple threads. I have merged with one of your previous threads, please stick to this one from now on.
That spec looks alright, if your maxed budget wise then I think you can go ahead and order, if you have anything left get the caviar black.
tombo
[EDIT BY MANTADOG advertising PCS competitors is against the rules]
And yes, your build will play Minecraft very happily. You could just get a better PC for the price.
Getting a gaming PC with ram less than 8gb is probably not a good idea.
