Minecraft 0 fps problem
lewishollings
Okay so everytime I play minecraft... which isn't very often I play for about 5 minutes and after that time it hit's like 1 too 0 fps and won't stop... shouldn't be having this problem with an i5 but can anyone let me know if they've had this problem and how too fix it.
Cheers!
LFFPicard
run a clean install of Java.
I believe if you download the latest java the advanced options have a clean install option.
Also make sure your installed the correct java, 32bit or 64bit
lewishollings
Hmm I had this problem before I actually restored my computer, it's the same after, I should probably add this is while using the technic launcher and playing voltz, but I will do what you said :)
LFFPicard
Let me know how it goes, there is a bat file you can create to dedicate ram to a minecraft server and use a specific Java, maybe it will work on the client as well so let me know how java re-install goes and I can help with the bat file if needed.
lewishollings
Hey man, it worked! because I was downloading on a 32 bit explorer, java assumed that my computer was 64 bit! had a look through there files and got the 64 bit download, hooray :)
