Mid-spec gaming rig
Looking to create a relatively future proofed rig to game on for the next 5+ years. Budget sits around £1600-£1800. Any suggestions on this so far?
Intel® Core™ i7 12-Core Processor i7-12700KF (3.6GHz) 25MB Cache
ASUS® PRIME B760-PLUS D4 (LGA1700, PCIe5.0, USB 3.2)
32GB Corsair VENGEANCE DDR4 3200MHz (1 x 32GB)
12GB NVIDIA GEFORCE RTX 4070 - HDMI, DP, LHR
Graphics Card Support Bracket
NONE (BRACKET INCLUDED AS STANDARD ON 4070 Ti AND ABOVE)
1TB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7300MB/R, 6000MB/W)
CORSAIR H100x RGB Elite High Performance CPU Cooler
ONBOARD LAN PORT
WIRELESS INTEL® Wi-Fi 6E AX210 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
Standard Build - Approximately 7 to 10 working days
Price: £1,732.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z690-pc/USzD5J4vM!/
sck451
I'd strongly recommend going in quite a different direction. First, the display. I would certainly recommend upgrading, but I'd be cautious about a 32" 1440p display as the pixel density is relatively low. I'd suggest a 27" instead: it will be much sharper.
Second, for the PC itself I'd be inclined to go with Ryzen 7000 instead of Intel. There's not a massive difference in terms of performance, but the efficiency and upgradability of the Ryzen chips is unparalleled.
Here's the system I'd suggest for you:
AMD Ryzen 7 7800X3D Eight Core CPU (4.2GHz-5.0GHz/104MB w/3D V-CACHE/AM5) To bring the price down you could get the 7700 instead; it'll be about as good today, but may be a little less future-proof (though it could easily be upgraded)
ASUS® TUF GAMING B650-PLUS WIFI (DDR5, USB 3.2, 6Gb/s)
12GB AMD RADEON™ RX 6750 XT - HDMI, DP - DX® 12 The more expensive option would be the 6950XT
500GB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7000MB/R, 3000MB/W) Fast boot drive
2TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2700MB/sW) Lots of game storage
CORSAIR 1000W RMx SERIES™ - MODULAR 80 PLUS GOLD, ULTRA QUIET Lots of power capacity (could be reduced to 850W to save a little cash)
PCS FrostFlow 150 Series High Performance CPU Cooler Enough for either the 7700 or the 7800X3D
ONBOARD 2.5Gbe LAN PORT
Windows 11 Home 64 Bit - inc. Single Licence [KUK-00003] Unless you can transfer your Windows licence from an existing PC?
Microsoft® Edge
Price: £1,811.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/ygHJeEHnnM/
Thank you so much for the advice - I really appreciate. I've made some adjustments and just wondered what you thought now. I've noted beside each part where I've made changes.
CORSAIR 5000D AIRFLOW TEMPERED GLASS GAMING CASE (Had to change the case to fit the 6950XT)
ASUS® PRIME B650-PLUS (DDR5, USB 3.2, 6Gb/s) - ARGB Ready!
32GB Corsair VENGEANCE DDR5 5200MHz (2 x 16GB)
16GB AMD RADEON™ RX 6950 XT - HDMI, DP - DX® 12 (Opted for both the more expensive CPU and GPU)
1TB SEAGATE FIRECUDA 530 GEN 4 PCIe NVMe (up to 7300MB/R, 6000MB/W) (I only needed 1 SSD to save on money - I don't keep a lot installed)
CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET (PCS prompted me that this would be enough power with a 20% window still)
Corsair H100x Hydro Series High Performance CPU Cooler (Opted for more cooling)
WIRELESS INTEL® Wi-Fi 6E AX210 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0 (I added a wireless card and swapped the motherboard to a non-wifi version as this saved money - unsure if this is wise?)
Price: £1,994.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/H8nRnKn9Ga/
sck451
The other thing with the drive is that a full SSD is slower than a mostly empty one. For an operating system drive this is really important. For a games drive it's less crucial. So having them separate allows you to use your drives much more efficiently – to fill up your games drive and still have a snappy operating system.
OK so, taking all your advice into consideration I've come up with the following: (Had to lower the graphics card to keep in budget - but I figure this could be amended years down the line)
CORSAIR iCUE H100i ELITE RGB High Performance CPU Cooler
Price: £1,901.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/Zxs4XxdPgj/
Made some changes by upgrading motherboard & RAM based on some suggestions I saw in other threads:
ASUS® TUF GAMING X670E-PLUS WIFI (DDR5, PCIe 5.0) - RGB Ready!
32GB Corsair VENGEANCE RGB DDR5 5600MHz (2 x 16GB)
Price: £2,062.00 including VAT and Delivery
When the upgradeability of the AMD chips is mentioned, what is meant by this exactly?
AMD is now on the AM5 platform, the first generation on that platform, but it's been promised support through 2025 at the minimum so will support another 2 or 3 generations of CPU.
Intel 13th gen is on the same platform as 12th gen, but that's now a dead platform, 14th gen is a new socket with different pin layout so won't fit. Intel also are famous for only ever supporting 2 generations per socket and forcing a new socket even though the chip design may not have changed. They're evil no-gooders that we poo poo.
