Hello everyone, sorry for my poor English in advance, and I can give more clarification if you don't understand one of my sentences.
I'm currently searching for a new laptop as my MSI is starting to randomly lag after 3.5 years, and is also suffering from keyboard and overheat. Even if I know that all laptop will suffer from heat eventually, will this spec be enough to run "high" game (The Witcher 3, Apex Legends, Cyberpunk (quite the exception as it seems to take a load of resources), ect.) in medium with 60 fps ?
The laptop that I currently own is suffering from overheating issue since day one, but today it's gotten way worse than before : 95 degree from both GPU and CPU after 5 minutes of running Overwatch, Dead By Daylight, Apex on medium/low, and I'm forced to put it down to 30 fps and lock my laptop on economy mode... It's maybe the thermal paste that's causing it, the dust, or the fan not working as much as before ? Anyways can the laptop from pcspecialist be open easily with the right tools, like an opening kit ? Is the overheating tolerable without having too much lag, or should I reduce the performance if needed ?
Thank you for reading !
And here's the spec :
Promotional Discount
Special Offer - Save Now On Intel Core i7 Powered Laptops - Offer Ends 30th December 2020!
Optimus Series: 15.6" Matte Full HD 144Hz 45% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Six Core Processor 10750H (2.6GHz, 5GHz Turbo)
16GB Corsair 2400MHz SODIMM DDR4 (2 x 8GB)
NVIDIA® GeForce® GTX 1660 Ti - 6.0GB GDDR6 Video RAM - DirectX® 12.1
1TB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 470MB/W)
1TB INTEL® 665p M.2 NVMe PCIe SSD (up to 2000MB/sR | 1925MB/sW)
AC Adaptor
1 x 180W AC Adaptor
2 x 1 Metre Cloverleaf European Power Cable
Optimus Series Detachable Lithium Ion Battery
1 x USB 3.2 PORT (Type C) + 2 x USB 3.2 PORTS + 1 x USB 2.0 PORT
AC Adaptor
1 x 180W AC Adaptor
