Mid Level Gaming PC & General Home Office Use
Jacko99
Please can you review and comment on the below spec and let me know any thoughts / modifications you would suggest for a mid level gaming system.
ZALMAN Z11 PLUS BLACK MID TOWER CASE
Intel® Core™i5 Quad Core Processor i5-4570 (3.2GHz) 6MB Cache
ASUS® Z87-A: ATX, USB2.0, USB3.0, SATA6GB/S, SLi, XFIRE
2GB NVIDIA GEFORCE GTX 650Ti BOOST- 2 x DVI, HDMI, - 3D Vision Ready
500GB SEAGATE HYBRID SSHD Drive, SATA 6 Gb/s, 64MB CACHE (5400 rpm)
Super Quiet 22dBA Triple Copper Heatpipe Intel CPU Cooler
Asus Xonar DGX 5.1-Channel Gaming Audio Card
WIRELESS 802.11N 300Mbps PCI CARD
DVD Recovery Media
Windows 7 Home Premium (64-bit) DVD with paper sleeve
Microsoft® Office Home & Student 2013 (1 License & Disc)
DVI-D & HDMI Monitor Cables
1 x 2 METRE GOLD PLATED V1.4 HDMI CABLE
Headsets
Creative HS-800 Fatal1ty Gaming Headset
Miscellaneous
FREE £50 IN-GAME VOUCHER with GTX 650 & GTX 650Ti GPUs!
Jacko99
Thanks Keynes, just a question on the sound card, would a standard card perform ok for sound critical games such as CSS and CSGO (3D sounds)?
Also which GPU would you recommend upgrading to?
Cheers
You could try onboard audio first, if you think you require something extra then go for the sound card but it also depends on the gear you have (speakers , headset). For gaming r9-270x or 280x but depends on your budget.
