Mid-high Range Gaming and Web Browsing
thoben
So I've been looking to upgrade my from my Dell Inspiron which is now getting a bit dated.
I was originally looking at getting one of those Alienware X-51s, they looked good and seemed to be "specced" quite well, all things considered, for my requirements. But my Dad pointed me towards this site and I have summarily put together this build.
Basically I'm looking for a build that will meet my gaming requirements for the next few years with perhaps just the odd GPU improvement if necessary. I don't need to be running something like Battlefield 3 on Ultra and in 1080p but I've got a pre-order on Company of Heroes 2 and would like to see some quality visuals from it.
COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE
Potential of this case seemed good, and I quite liked the styling as well. Basically a wide range of improvements over the SFF of the X-51.
Intel® Core™i7 Quad Core Processor i7-3770K (3.5GHz) 8MB Cache
My brother suggested the overclocked version of this processor and it wasn't much more expensive than the normal 3770.
ASUS® P8Z77-V LX: USB 3.0, SATA 6GBs, ATI®CrossFireX
Not entirely sure on the Motherboard. Feedback would be evry much appreciated here along with any suggestions for a better or more suitable one.
£20ish to double my memory from 8GB? Why not.
2GB NVIDIA GEFORCE GTX 660 Ti - 2 DVI, HDMI, DP - 3D Vision Ready
Any advice here would be great. Based my choice on getting a better version of what is available in the X-51.
120GB INTEL® 330 SERIES SSD, SATA 6 Gb/s (upto 500MB/sR | 450MB/sW)
Double HDD selection on the advice of my Brother. Run games off the SSD and use the 1Tb drive for general storage.
12x BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW
Wanted a Blu-Ray drive and my Dad suggested getting the Re-Writer variant of what was on offer
Room for expansion was the thought here. My Inspiron lacked a power surplus so was difficult to upgrade. I don't think this system build here takes more than 450W.
Wasn't entirely sure on this choice. Again advice would be great if there is something more suitable.
Came as standard, didn't think I would need any more than this.
DUAL-BAND WIRELESS 802.11N 450Mbps PCI-E CARD (£35)
Dual Band upgrade suggested by Dad
LOGITECH® G110 GAMING KEYBOARD WITH BACKLIGHTING (£69)
Mouse
LOGITECH® G500 LASER GAMING MOUSE (£45)
Price: £1,291.00 including VAT and delivery.
£1,291 is reaching the top end of my budget. ideally I wouldn't want to spend more than £1,300
Thanks in advance for any help and feedback offered.
Most games are gpu intensive and there is no need for overclocking, not sure whether or not company of heroes is cpu intensive. If you plan to overclock the cpu you would need to upgrade your cpu cooler.
If you want to SLI you need to upgrade the motherboard and PSU to at leasr 750w.
For gaming, depending on what games you play, I'd suggest the GTX 670.
A caviar black will be faster. If you are planning to run games from the SSD it depends on how many games you have and their size. Some games occupy more than 20gb.
thoben
Thanks for the feedback.
Ruben, I don't plan on overclocking so I guess I don't need that feature in my CPU. Tiberias subsequently suggested an i5-3570. Now I've heard of the debates regarding what is better for gaming i7 or i5 processors, but is it worth going with the normal i7-3770 instead of the i5? The i7 is the top of the range CPU from intel is it not?
Would either of you recommend using two GPUs? I would definitely consider changing the motherboard and PSU if there is a notable performance change for the increased cost. Also could this be done further down the line? I'm already pretty close to my budget, but start saving again and i could potentially upgrade and add an additional GPU later.
Thank you for the Caviar Black HDD suggestion, I can see Tiberias added that to the improved spec. I don't have many games, and only tend to play World of Tanks and Company of Heroes to be honest, so capacity on the SSD should be alright with the 180GB Intel 330 series Tiberias added.
I've not heard of Homeplugs before. I use a BT Home Hub currently, do they interface with that?
Would it be worth splashing a bit more cash on the Geforce GTX 690 for the GPU?
Again thanks for your help, really appreciate it. Only ever bought Dell before, so this would be a refreshing change to get one built from the ground up
No, a pair of GTX 670 will provide close performance and be significantly cheaper.
You need one close to the router and one close to your pc.
It depends on your budget and your intended use, if you are planning to run more cpu intensive programmes then the i7 will be a better choice.
thoben
Thanks for getting back to me again.
Other than gaming, which as you said is usually GPU not CPU intensive, I can't think of anything else I will do that is CPU intensive. So the i5 should be fine. The Hyperthreading of the i7 is not really needed for my requirements.
Updated Spec is:
2 x HomePlug 200Mbps - Turn any Electrical Socket into a Network (£38)
Mouse
Price: £1,301.00 including VAT and delivery.
Basically the only change from what Tiberias posted earlier is the Motherboard. I chose the SLI version to give myself the option in the future. I did look to see the cost of a dual GTX670 build with the uprated PSU but it was way over my budget.
With this option, I should be able to afford it when it comes to upgrading in the future. Will just have to get saving again for the additional £400.
Thanks for the help Ruben and Tiberias, much appreciated.
If you are planning to SLI in the future you would need to upgrade the PSU to 750w.
thoben
Checked your suggestions in the build, dropping the keyboard and mouse and going third party for those looks like a good plan, and I'll be able to get a 750W PSU in there well inside my budget now.
Do either of you know the particular differences between the Corsair Pro and Enthusiast series'? Particularly the difference between the two 750W versions? Would it be worth going for the Pro series 750W over the enthusiast?
I think the main difference is the more expensive one is modular.
thoben
Hi guys sorry for the very late reply.
Just wanted to thank you both Rubensolo and Tiberias for the help. Your advice was invaluable as I'm sure it is for many people using PC Specialist. I rated both your reputations up, a small gesture of my appreciation :)
I just have one more question.
As you know I've gone for a build that will allow me to add an additional GPU in the future with the SLI capable motherboard. Will it be a simple case of slotting the additional GPU into one of the PCI-E slots, or is there some additional set-up required?
Thanks in advance.
Thanks in advance.
Fitting the new GPU and using a SLI bridge that should be provided in your welcome pack. Then you can enable SLI by going to nvidia control panel.
