Hello,
For probably the past two weeks (but especially the last few days), I have been noticing consistent microstuttering and even large pauses and stutters, along with audio delay, in a number of games, ranging from Doom Eternal, to Apex Legends, to Halo MCC and especially Total War: Three Kingdoms. I initially noticed it in Three Kingdoms and thought that it was an issue unique to that game, but it feels like it must be a system level issue with how many games I am experiencing it in.
It should be noted that:
About a few weeks before this issue occured, I upgraded from two 1080p 60 Hz monitors to one 1440p 165 Hz monitor and a 1080p 60 Hz monitor.
I am on the latest Radeon drivers, and do beleive I noticed the issue get worse after the latest drivers.
I am on the latest Windows update, and I believe I had issue beforehand, but they have gotten worse sense.
I've been trying to solve it myself over the past few days, to pretty much no avail.
Here is what I've tried:
Disabling all overclocking and resetting my motherboard to default settings.
Turning on and off DOPP at default settings.
Adjusting RAM settings and speed.
Opening up the case to ensure that all cables are fitted correctly (which they were, and very nicely managed).
Plugging in and out all my USB devices.
Plugging in and out all my monitors.
Installing MSI Afterburner and modifying settings, then disabling it and uninstalling it.
Turning on and off Freesync and Freedsynch Premium.
Turning off Enhanced Sync.
Moving games between my SSD and HDD.
Shutting down all other programs besides games.
Disabling Discord overlay.
Turning off a number of background services.
Running virus scans.
Checked temperatures to see if I would ever get throttling while playing, and nothing I play ever causes the CPU to go above 70, and the GPU above 80.
Checked for updated drivers for everything.
And a bunch of other steps I have forgotten.
Specifications:
COOLERMASTER SILENCIO S600 QUIET MID TOWER CASE
ASUS® TUF GAMING B550-PLUS WiFi (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
16GB AMD RADEON™ RX 6800 - HDMI, DP - DX® 12
512GB PCS 2.5" SSD, SATA 6 Gb (520MB/R, 450MB/W)
ASUS ROG STRIX 850W MODULAR 80 PLUS® GOLD
Windows 10 Professional 64 Bit - inc. Single Licence
Firefox™
Monitor Cables
1 x 2m DisplayPort Adapter Cable - DP to DVI
Standard Build - Approximately 9 to 12 working days
Welcome Book
Logo Branding
PCSpecialist Logo
The specific 6800 I have is a PowerCooler Red Dragon which is apparently one of the really good ones - thanks PC Specialist c:.
Current overclocking:
Ryzen 7 5800X @ 4.5 Ghz, 1.27500 V iirc. I've had it as high as 4.6 and that doesn't appear to have affected anything.
6800 Manually overclocked to 2350 MHz, 1025 V, VRAM 2130, Power Tuning 10%
Not using XMP / DOPP for RAM currently, but on or off makes no difference. I've gotten it to be stable at 3000 MT/s (and probably stable at 3200 MT/s?) before.
I have enabled resizable BAR.
The only special Graphics setting i have enabled globally is Image Sharpening.
I have seen some stickies and am planning to install the latest Ryzen chipsets.
What should my next steps be? I'm pretty confused what could be the problem at this stage.
EDIT: it does appear that over the past two days hte longer the pc has been on and perhaps the more restarts, the worse the problem gets. It did get better when yesterday when I unplugged it, inspected it, and then started it back on again.
Specifications:
Firefox™
Monitor Cables
Welcome Book
Logo Branding
PCSpecialist Logo
