Mic volume too low
Ab Ali
Hi, I've ordered my pc from here about 2-3 months ago everything seems perfectly fine except 1 problem my mic volume is too low I've tried so many different headsets thinking it was the problem however I've realised it could be with the pc i do have a 3.5mm splitter i tried putting volume to the max nothing seems to work my friends cant hear me well when i play with them. Is there anyway anyone could help please thank you. Here are my specs.
512GB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 3500MB/sR, 1625MB/sW)
1TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 2950MB/sW)
CoolerMaster Hyper 212 (120mm) Fan CPU Cooler Black Edition
Microsoft® Edge
Price: £1,340.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/kcsgnAA40x/
Ab Ali
Ab Ali
Does the same happen out of the case ports?
The headset you linked is the console version which doesn't come with a splitter, where did you source the splitter?
i have not tried the case port
and this is the splitter im using https://www.amazon.co.uk/Jelly-Tang...074N6XLHT/ref=cm_cr_arp_d_product_top?ie=UTF8
