hi
I'm using the premium version: 2.0.2.1012
Something in the registry records I have purchased the permium version.
"uncheck the box to run a trial of the Pro version" I didn't see any box to select.
I wouldn't do that,I have the same set up security essentials and premium Malwarebytes.So do you recommend turning off real-time protection for Microsoft Security Essentials. Before scanning with malwarebytes.
http://i1306.photobucket.com/albums/s579/jbaccrington/MicrosoftSecurityEssentials_zps5559fdf1.jpg
I wouldn't uninstall or disable Security Essentials,Malwarebytes isn't meant to be run on it's own,it's designed to sit beside your traditional internet security suite, filling in any gaps in its defences, providing extra protection against sneakier security threats that normal antivirus programs won't detect.
http://www.pcadvisor.co.uk/reviews/security/3508201/malwarebytes-anti-malware-premium-review/
