I've had my new PC 2 days and to be honest it's been no fun at all...
Friday and Saturday have been nothing more than a painful hunt for the cause of constant blue screens...
Started with the obvious by removing the O/C and running defaults, no change.
Next was trawling through the numerous mini dumps to find out it was the Nvidia drivers due to the HD audio and server component for Nvidia Shield.
Next problem was Daemon tools which brought a number of freezes, no BSOD just a locked up system, so in the bin with that !
All was looking good and set about transferring some of my work files from the old PC across the lan, all was looking good until this morning I find a PC sat cycling an attempt to reboot !!
This is not a software reboot at it isn't posting and is switching off and on at 1 second intervals !!
Asus start button and reset buttons do nothing the only clue I can see is the motherboard has Q LEDs and the only one lighting up before the 1 second cycle is the CPU light !!
So if it is the CPU does that mean I have a faulty H100 being as all the clocks where set to default while tracking the BSOD problem from the day I got it !!!!
Any ideas on how to proceed ????
Symptoms are, hit the on switch on the PC and it spins up 1 second lighting up GFX cards and cooler, PSU clicks and powers down and 1 second later tries to power up and just continues like that...
Not a good start for life with a 3K PC....
- Corsair Graphite Series 600T White
- Intel i7-4770k O/C 4.2 Ghz
- Asus Maximus VI Hero
- 32GB Kingston HYPERX Beast (2400MHz)
- 240GB Intel 520 Series SSD
- 2TB WD Caviar Black
- 3GB Geforce GTX 780 (2 way SLI)
- Corsair H100i Hydro
- Corsair 1050W Pro HX1050-80
