Had my build over a month now and I can't praise it enough.
Spec is below.
It arrived in just under a couple of weeks.
Folks here gave me some great advice as I use it for gaming watching films. The Fractal R5 case and Noctua combo is great. I can barely hear it even when the front of the case is open.
I use it a lot for World Community Grid science processing. The Intel Turbo-boost really helps that with all six cores running at 4.3GHz. Temps are good too - 30C idle, 60 under load
I would post a picture but it'd be of a black box, no fancy side panels.
Installing my Blu-ray drive and Hard drives was easy (only m2 drive was from PCS), although there was a very minor issue regarding cable tidy being clipped to a drive tray but PCS are aware this happened so hopefully it won't happen to anyone else.
Would def recommend to others.
Spec is below.
