Hi there.
I received my new PC on Friday and have had some issues with the fans and noise coming from the system. My case is a CoolerMaster Masterbox TD500 Mesh which came with 3 preinstalled front fans. They rev up quite a bit when opening apps, including Edge, and will sometimes rev up randomly for a few seconds. I'm not surprised that they get loudly when opening applications but they are fairly audible. It also sounds like there's a very faint rumbling or clicking noise. On idle it sounds as though there's a Transit van sitting outside my window.
I received Warhammer 40,000: Darktide with my RTX 3080 and it got crazy loud. The default Graphics settings were set to High and Ray Tracing was set to Medium. I lowered the graphics to Medium and turned Ray Tracing off, and while it did seem to calm down a bit it was still very loud. It's much quieter with older games, which isn't a surprise, but I was expecting it to be way quieter. Performance is great though! I just feel like I'm sitting next to a jet engine.
I'm not exactly sure how to control the speed of my fans other than through BIOS. I saw a recommendation online to switch my fans from DC to PWM via BIOS but this only seemed to make them louder, so I switched them back to DC. I don't want to touch anything else until I know that I'm doing.
I have iCUE preinstalled but I'm not entirely sure if my case fans are connected to it, it looks like it's just the motherboard, RAM, GPU and CPU cooler that are connected. I'm not sure how to control the fans for those components either. I tried installing Armoury Crate from the ASUS website but the installer is just hanging at around 90% complete. Weirdly enough, before I tried installing Armoury Crate, I found a folder named ARMOURY CRATE Lite Service under ASUS in Program Files but there doesn't seem to be an actual app on my PC which allows me to open it.
I'm a little stumped and not really sure what to do now, so looking for some advice on how to make my PC run quieter.
My specs are:
Thanks.
My specs are:
- Case: CoolerMaster Masterbox TD500 Mesh
- Case fans: 3 at front, 1 at back (didn't ask for the one in the back but they must've figured I'd benefit from it)
- Motherboard: ASUS Rog Strix B550-F Gaming
- CPU: AMD Ryzen 7 5800X3D
- CPU cooler: Corsair iCUE H150i Elite
- GPU: RTX 3080
- RAM: 32GB Corsair Vengeance Pro (2 x 16GB)
- SSDs: 1x 500GB Samsung 980 Pro, 1x 2TB Samsung 980 Pro
- PSU: Corsair 1000W RMx Series Modular 80 Plus Gold
- OS: Windows 11
Thanks.
