Lots of lovely colours and a great spec
DaveGar
So this is the main information about my new PC
Case PCS SPECTRUM G ARGB MID TOWER CASE (PWM) Processor (CPU) Intel® Core™ i7 16-Core Processor i7-13700K (Up to 5.4GHz) 30MB Cache Motherboard ASUS® PRIME Z790-P (DDR5, LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready Memory (RAM) 32GB Corsair VENGEANCE RGB DDR5 5600MHz (2 x 16GB) Graphics Card 12GB NVIDIA GEFORCE RTX 4070 - HDMI, DP, LHR Graphics Card Support Bracket NONE (BRACKET INCLUDED AS STANDARD ON 4070 Ti AND ABOVE) 1st M.2 SSD Drive 2TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 3325MB/sW)
So far I'm very pleased with it. I was able to transfer in the hard drives from my old Chillblast PC pretty easily which made things a lot better. My only gripe is that I seem to have very limited control of the colours, in particular the fans. I enquired about this and was told there should be a couple of apps installed but Armory lite doesn't seem to want to run....
I am glad I bought this PC. It has made many things much faster and easier to run. Also as a pre-built, it arrived less than 24 hours after I ordered it!
Great service.
Dave
Daniel.winyard
You might be able to find drivers on the PCS tech sup page of your account for the app. You can also contact them through the chat option. I tansferred my SSD from my old laptop to my new one and couldn't get the sound to work well, and they sent me the right driver. If you haven't tried that it might be worth it.
On a desktop you don't get drivers from your PCS account, they all come from the manufacturers download sites.
It's only laptops where you would use your PCS account.
