I don't really want to spend over £850. Can you cast an eye over the below please?
AMD PHENOM II X4 970 (3.50GHz/8MB CACHE/AM3) - BLACK EDITION
ASUS® M4A87TD/USB3: DUAL DDR3,SATA 6.0GB/s, USB 3.0
1280MB NVIDIA GEFORCE GTX570 - 2 DVI,mHDMI - DirectX® 11, 3D Vision Ready
2nd Graphics Card
NONE
NONE
RAID
NONE
2nd DVD/BLU-RAY Drive
NONE
CORSAIR 650W TX SERIES (TX650) 80+ ULTRA QUIET PSU (£78)
Sound Blaster® Audigy™ SE (£19)
I have gone for the £5 warranty option too.
SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE CPU COOLER - will this actually make much difference on cooling performance??? is it needed? Im not too bothered by noise really but if the cooling power is a lot better than standard then i will get it!
Cheers!
2nd Graphics Card
NONE
NONE
RAID
NONE
NONE
Cheers!
