Looking for advice on what I should upgrade first?
dracula468
Hey guys
Didn't really know where this should go but I've had my PC for maybe a month and absolutely love it but I'm looking for advice on what I should upgrade first?
My current specs are;
Case - NZXT PHANTOM 410 WHITE GAMING CASE
Processor (CPU) - Intel® Core™i5 Quad Core Processor i5-4460 (3.2GHz) 6MB Cache
Motherboard - ASUS® H81M-PLUS: Micro-ATX, LG1150, USB 3.0, SATA 6GBs
Memory (RAM) - 8GB KINGSTON DUAL-DDR3 1600MHz (1 x 8GB)
Graphics Card - 2GB AMD RADEON™ R7 370 - DVI, HDMI, DP - DX® 12, Eyefinity
Hard Drive - 1TB 3.5" SATA-III 6GB/s HDD 7200RPM 32MB CACHE
DVD Drive - 24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Power Supply - CORSAIR 450W VS SERIES™ VS-450 POWER SUPPLY
Processor Cooling - INTEL STANDARD CPU COOLER
Any advice would be fantastic.
Thanks guys :)
Without indicating your budget and intended use is difficult to give advice on potential upgrades. Is it struggling running your applications/programmes?
dracula468
There isn't any major problem, the only problem I can think of is that when playing games my fps will drop but then goes back to normal. I didn't state a budget because I don't plan on doing it all at once, I was going to buy something each month regardless of price, as long as it was beneficial.
I think it depends on your budget. Not sure what games you play but for instance you could consider a gpu upgrade but that involves a psu upgrade as well. If the games you play are running ok and you are happy with performance then an ssd?
Warbloke
Before you plan on getting the GTX970, or indeed a 980Ti... you should also plan on upgrading your Power Supply Unit first, as 450W seems too low to power either of these GPUs.
(edit: which I see Keynes said above "you could consider a gpu upgrade but that involves a psu upgrade as well")
Id also agree an SSD would be a good upgrade, and its something that is a really noticeable improvement too, (if you make that your primary Windows/ boot drive instead of the current one anyways)
