looking for advice on a quiet CPU cooler - for AMD Ryzen 9 5900X
hi all,
I'm looking for advice on which CPU cooler option to pick for minimum noise.
I'll be going for the AMD Ryzen 9 5900X - see full specs below - Thanks :)
10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP (Delivery before Xmas not guaranteed)
4TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
Windows 10 Professional 64 Bit - inc. Single Licence [MUP-00003]
MrWilson
For the Fractal case I would personally recommend the H115i RGB PRO XT over the Platinum. Functionally, they are the same cooler but the extra RGB fans on the Platinum are somewhat redundant as the case has a solid side panel. The cooler comes with premium thermal paste pre-applied so you don't need the arctic thermal paste and yes, you won't need the extra 2 case fans.
You could optimise your storage a little more by adding an M.2 SSD as your OS drive, this will lead to much faster boot times.
i've updated it - i didn't see the M.2 SSD option at first, thanks!
1TB INTEL® 665p M.2 NVMe PCIe SSD (up to 2000MB/sR | 1925MB/sW)
Corsair H115i RGB PRO XT Hydro Series High Performance CPU Cooler
