Looking for advice kindly please
St3rling
Hi all,
I would like some advice please on this spec below, yes I know for that money I could build a super desktop etc but due to my lifestyle that cannot be done.
Laptop will be used for high-end gaming and the usual day to day but focusing on gaming. This laptop would replace my Asus ROG G751JY laptop.
Octane Series: 17.3" Matte Full HD 120Hz IPS LED Widescreen (1920x1080)
Intel® Core™i7 Quad Core Processor i7-7700 (3.6GHz) 8MB Cache
16GB Corsair 2133MHz SODIMM DDR4 (1 x 16GB)
NVIDIA® GeForce® GTX 1070 - 8.0GB GDDR5 Video RAM - DirectX® 12.1
1st Hard Disk
500GB SERIAL ATA III 2.5" HARD DRIVE WITH 32MB CACHE (7,200rpm)
M.2 SSD Drive
256GB SAMSUNG SM961 M.2, PCIe NVMe (up to 3100MB/R, 1400MB/W)
External DVD/BLU-RAY Drive
AC Adaptor
1 x 330W AC Adaptor
Bluetooth & Wireless
GIGABIT LAN & WIRELESS INTEL® AC-8265 M.2 (867Mbps, 802.11AC) +BT 4.0
4 x USB 3.0 Ports + 2 x USB 3.1 Type C Ports
Octane Series 8 Cell Lithium Ion Battery (82WH)
OCTANE SERIES BACKLIT UK KEYBOARD WITH NUMBER PAD
Firefox™
Notebook Mouse
INTEGRATED 2.0 MP FULL HD WEBCAM
Dead Pixel Guarantee
Insurance
Price £1,892.00 including VAT and delivery
Top is 2k :) Any advice would be highly appreciated. Thank you guys :)
Stephen M
The Octane is great, i have one but at nearly 4kg and with a massive power brick it is not the most portable of laptops. It will certainly do all you need it for but so might a Defiance and that would be a lot better for moving around. What will you do when the 30-day trials of Bullguard and Office finish, you could go for Avast for anti virus and Libre or Open Office as they are all free and as good as paid for versions.
If gaming is the focus, you could look at the Defiance - it has a laptop i7 7700HQ rather than a desktop i7 7700, but many games aren't going to care a great deal and the Defiance is a lot cheaper.
St3rling
Thank you for the advice guys, much appreciate it!
The weight is not that of a huge problem as I do travel but not ultra frequent, I can coop with that. What about the cooling aspect of things, would it be the same or similar any input on that? as the housing would be different. I just do not really want high temp on CPU nor GPU and overall due insufficient cooling. Is the hdd/ssd managment ok or shall i change smth there? Video card I was reading up on and not much maybe 10-15% increase on the 1080 so guessing 1070 will be just fine.
Sorry a lot of questions but I'd like to clarify everything as this will be a huge spend after a long time saving :)
Thank you! :)
Stephen M
The m2 you have chosen is the one I would have gone for, the 1TB SATA 7200rpm HDD is only about eight GBP more than the 500 so I would change up there, you may well need the storage space and it is not a big outlay.
I have not had heat issues with my Octane but I do not game, although do a lot of video work and that can get temps going up. Whatever model you choose I would recommend a cooling tray as they do help and in any intensive use temps will go up but if you get a 17.3" laptop check the tray can take it as there are some advertised as OK for large laptops but barely take a 15.6"
I will leave the GPU advice to others as not being a gamer am not in position to say.
St3rling
Hi Stephen M and thank you for your advice :)
The thing is I will need the 17.3 screen as simply got used to it in the past years :) but definitely upgrade for a bigger HDD, true not much of price difference and gives me more space.
Yet I'd still like some more clarification on GPU and drive management and is it worth getting 32GB ram or 16GB will suffice? Doubt though yet still worth asking :) but that's fine you've helped a lot already, much appreciate it!
Thank you! :)
Stephen M
I have a Xigmatek cooling tray, PCS used to sell them but that was three years ago but if you can find one they do fit 17.3" laptops. I agree about the screen size, although my reasons are also down to eyesight issues as am an old git. You may also find a cheaper external DVD drive if you shop about.
Rakk
The Awesome
Given it looks like you'll be using it for gaming and other generic stuff, 32GB of RAM is unnecessary - 16GB of it would unlikely ever be used, so 16GB will be plenty.
St3rling
Thanks Stephen M and Rakk for the input, wow you are all very helpful, love it :) as for the RAM shall I opt for the 2400Mhz, that might be a nob question and I know there is literally no difference in gaming maybe 1-2 fps increase but it only cost 2 quid more :D would it be compatible with everything instead of the 2133Mhz one?
Stephen M
It should be OK and worth it. When you put the specs in the configurator and click on "proceed" if there is anything not compatible it will warn you then
St3rling
Yes, I have tried it and it was all ok except it asked me whether I'd like the OS installed on ssd or the hdd and the ssd drive was recommended in brackets, supposing it is the right way doing that so.
Rakk
The Awesome
Yes, you definitely want the OS on the SSD :)
St3rling
In that case I think it will look like this:
16GB Corsair VENGEANCE 2400MHz SODIMM DDR4 (1 x 16GB)
1st Hard Disk
1TB SERIAL ATA III 2.5" HARD DRIVE WITH 32MB CACHE (7,200rpm)
M.2 SSD Drive
AC Adaptor
1 x 330W AC Adaptor
Firefox™
Notebook Mouse
Insurance
PCS EXTRA-CARE DELIVERY TO UK MAINLAND - MON-FRI, PRE-NOON
Price £1,911.00 including VAT and delivery
Looks solid to me, what do you guys think? :) Any other tweaks/changes you'd make?
