Looking for advice before purchasing
hillgww
I mainly use my laptop for video editing, 3d animation and gaming at weekends. Due to now perminatly working from home looking to move to desktop. I'm wondering if there are any changes I should make to this configuration? Cooling and power are above my knowledge level. I have a 2nd SSD (WD black) that I will add for videos files.
Monitor is Dell S2417DG 23.8-inch 1ms Response Time, QHD. + another 60hz monitor. Looking for £1,800ish. Could go further if it's justified.
Thanks for any help.
Intel® Core™ i7 Eight Core Processor i7-11700K (3.6GHz) 16MB Cache
GIGABYTE B560 AORUS PRO AX (rev. 1.0) : LGA1200, USB 3.2, PCIe 4.0, CrossFireX, Wi-Fi - ARGB Ready
16GB Corsair VENGEANCE DDR4 2400MHz (1 x 16GB)
2 PORT (1 x TYPE A, 1 x TYPE C) USB 3.1 PCI-E CARD + STANDARD USB PORTS
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
Price: £1,996.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z490-pc/WYMkAQN2J3/
JUNI0R
PCS PRISM TG BLACK ARGB MID TOWER CASE
8GB NVIDIA GEFORCE RTX 3070 Ti - HDMI, DP, LHR
Heya! A few areas where we could improve this build. Firstly though, would we be able to get some more info?
1) Budget, what do you plan to spend?
2) Uses, you've mentioned video editing, 3d animation and gaming, will you now be using this PC for those uses? What software do you use and what games do you play?
3) What monitor will be hooked up to this PC? Especially important for gaming, either make and model or resolurion and refresh rate would be ideal!
4) The full spec and green configurable link. As much as it may not seem that way, your delivery, warranty and anti-virus choices are all equally important, would you be able to post the full spec along with the green link at the bottom, it makes suggesting changes a lot easier!
Once we have this info, we'd be happy to help!
hillgww
So mostly premier pro, after effect for video editing. And a bit of 3DS max (1x a month). Game wise CoD, GTA are my regulars. Jedi Fallen order is on the buy list. Will use this PC for all of that. I am wondering about waiting for the 3080 or just going with the 3070ti.
