quackchung
I have a Logitech G923 race wheel that MUST be plugged into a spare USB 2.0 port on my PC case (FRACTAL FOCUS 2 ARGB GAMING CASE ) otherwise you get issues with dropouts when attached to a hub (even powered) or the likes.
The issue is that the race wheel's USB lead is too short or even awkward to plug/unplug when required at the back of my case.
I was, but haven't yet thinking of using a short 480mbps 1M USB 2.0 extender cable, as that seems the logical thing to do. But further research sort of states the reason for the wheel's cable length being the length it is, is for optimum power requirements at its standard length. Obviously they've worked out that any longer could create instability.
The next logical answer is to use an (active) USB 2.0 extender, but I don't like the extra long lengths they come in. 1 or 2 M would be fine I suppose, but can't seem to find any.
My case does have 2x USB.3.0 ports on top which are not suitable, and I'm not sure how easy it would be to swap them out for USB 2.0, as they look purpose built in.
It also seems an additional USB 2.0 back chasis strip is not an option too, as it interferes with the GPU..."*Additional brackets available from Fractal but will limit GPU and front radiator support"...as stated on the case specs. There are no front bays with this case, plus one side is glass, the other metal.
I suppose I could purchase and connect a USB 2.0 Bay strip to the MOBO and MacGyver a hole in the metal side of the case for it to hang out if the supplied lead was long enough as a last resort.
Has anyone else had this problem and maybe some solutions or ideas for me to try out?
FRACTAL FOCUS 2 ARGB GAMING CASE (BLACK)
Promotional Item
AMD Ryzen 9 7900 12 Core CPU (4.0GHz-5.4GHz/76MB CACHE/AM5)
32GB Corsair VENGEANCE DDR5 6000MHz CL40 (2 x 16GB)
16GB MSI GEFORCE RTX 4060 Ti VENTUS 2X BLACK OC - HDMI, 3 x DP
1TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 2950MB/sW)
PCS FrostFlow 200 Series High Performance CPU Cooler
ONBOARD 2.5Gbe LAN PORT
Windows 11 Home 64 Bit
Promotional Item
