Load Fans
obioan
Hi I just recently purched a pc for PC Specialist , the only issues i have are that the fans are really loud and when im playing video games the temperatures are kinda of high could you offer some advice, please.
obioan
Hi my specs are the following:
THERMALTAKE VIEW 51 SNOW ARGB TEMPERED GLASS GAMING CASE
Promotional Item
Get Diablo IV standard edition plus additional content with Select GeForce RTX 40 Series!
Custom Liquid Cooling Kit
Liquid Series RGB High Kit - Corsair Hydro X - White
Tubing
Clear Hardline PETG Tubing (Bent/Metallic Fittings)
Graphics Card Cooling
GPU Water Block - For One Graphics Card!
Coolant Colour
Mayhems X1 UV Green
LED Lighting
3 x 50cm Green LED Strip
Intel® Core™ i9 24-Core Processor i9-13900K (Up to 5.8GHz) 36MB Cache
ASUS® ROG MAXIMUS Z790 HERO (DDR5, LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
32GB Corsair VENGEANCE RGB DDR5 6000MHz (1 x 32GB)
24GB ASUS ROG STRIX GEFORCE RTX 4090 - HDMI, DP
4 x Corsair LL120 RGB LED Fan + Controller Kit - WHITE
ASUS STRIX Raid DLX 7.1 PCIe sound card
48 HOUR INSURED PALLET DELIVERY TO UK (MON-FRI, INC. HIGHLANDS & ISLANDS)
Welcome Book
Logo Branding
PCSpecialist Logo
And my issues are:
- that the fans are too loud on normal mode and even on quiet mode which I've changed from the bios because I cant form the ICUE,
-The temperatures of the graphics card are going to over 80 degrees and the processor over 80 as while while gaming
Could you offer any support or advise for this.
Thank you
BIOS won't be able to control the fans as they're plugged in via an iCue controller, not the motherboard.
What do you mean by "I can't form the iCUE"?
obioan
Here this is when the fans are on normal mode from the bios, when i put them on quiet mode they get between 60 and 64 for the graphics card and the processor
We're not going to be able to evaluate without knowing the specific load applied and which temp is referencing what.
You definitely don't want it on Quiet, it's not powerful enough generally except for basic desktop use, but you need to apply this from iCue as in the link above.
I think on the GPU, Temp1 is the GPU, Temp2 is the hotspot, but it's all laid out much better in something like HW monitor, but those temps look pretty good to me
It's better to install HWMonitor: https://www.cpuid.com/softwares/hwmonitor.html
Have it open on the screen just before you start the test so you can screenshot both CPU and GPU temps
Then firstly run Furmark to stress the GPU (applied a known load of 100%) for 10 minutes and take a screenshot of temps at the end while the test is still running: https://geeks3d.com/furmark/
Then run a 10 minute run of Cinebench R23 and take screenshots at the end again while it's still running: https://www.maxon.net/en/cinebench
