Hi There, I've got a liquid cooled machine with a custom loop with two radiators. It cools the CPU and two GPUs. Over time the liquid has evaporated and I think its probably due a flush out and servicing. However in the mean time (use the machine for work) can I top up with premix coolant for the time being? until I get a free day to do the maintenance? The reservoir level is roughly about half at the moment.
Specs below as well as a shot of the coolant level.
Any advice would be welcome
Case | COOLERMASTER COSMOS C700M TOWER GAMING CASE |
Custom Liquid Cooling Kit | Liquid Series RGB High Kit - EK |
Tubing | Clear Flexible Tubing (Black Fittings) |
Graphics Card Cooling | GPU Water Block - For Two Identical Graphics Cards! |
Coolant Colour | Mayhems Pastel Raspberry Purple |
LED Lighting | 2x 50cm RGB LED Strip |
Overclocked CPU | Overclocked Intel® Core™ i9-9960X 16 Core (3.10GHz @ up to 4.3GHz) |
OC BIOS FIle | |
Motherboard | ASUS® ROG STRIX X299-E GAMING: ATX, USB 3.1, SATA 6 GB/s, WIFI - RGB Ready |
Memory (RAM) | 64GB Corsair VENGEANCE DDR4 3000MHz (4 x 16GB) |
Graphics Card | 11GB NVIDIA GEFORCE RTX 2080 Ti - HDMI, 3x DP GeForce - RTX VR Ready! |
2nd Graphics Card | 11GB NVIDIA GEFORCE RTX 2080 Ti - HDMI, 3x DP GeForce - RTX VR Ready! |
1st M.2 SSD Drive | 2TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W) |
2nd M.2 SSD Drive | 2TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W) |
1st Storage Drive | 6TB SEAGATE BARRACUDA PRO 3.5", 7200 RPM 256MB CACHE |
Power Supply | CORSAIR 1200W HX SERIES™ MODULAR 80 PLUS® PLATINUM, ULTRA QUIET |
