Im new to pc gaming and all aspects of building etc. purchased a gaming pc set up last year in Feb from here and I am concerned that the liquid cooling has never been working correctly as my pc has alway hit higher temperatures and can heat up entire rooms quite quickly.
I had a friend over who is more knowledgeable about PCs to show him Baldurs Gate 3 and he picked up on the cooling issue and advised me to contact forums or pcspecialist directly.
Keeps hitting temperatures of around 83c and it doesn’t seem like the liquid is moving in tubes as there are a couple of bubbles in the pipes that I would assume would move around if the flow of liquid was working.
CPU keeps hitting higher temps and it seems there is a buildup of something on top pipe coming from cpu tube.
How do I tell if it’s working as it should be + how do I fix this if it’s not working?
Additional: The liquid colour seems to have gone a lighter colour/odd looking from what it was.
Any help appreciated.
EDIT: first pic is pc in first week of having where liquid level on the back plate isn’t full…
The other pics are last night showing the liquid had expanded or something and is slightly discoloured.
Thought it may be a good comparison between them like a then and now if that helps.
Last pic of temperature is from being at the title screen of Baldurs Gate 3 for only 4 minutes to give as an example of temp.
Pc specs below copied from order form.
LIAN LI O11DYNAMIC XL ROG CERTIFIED GAMING CASE
Custom Liquid Cooling Kit
Liquid Series RGB Lian Li PCO11D – EK
Tubing
Clear Hardline PETG Tubing (Bent/Metallic Fittings)
Graphics Card Cooling
GPU Water Block - For One Graphics Card!
Coolant Colour
EK-neon green
LED Lighting
2 x 50cm UV LED Strip
Overclocked CPU
Overclocked AMD Ryzen 9 5950X 16 Core (3.4GHz @ up to 4.55GHz)
ASUS® CROSSHAIR VIII HERO WIFI (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
24GB NVIDIA GEFORCE RTX 3090 - HDMI, DP
2 PORT (1 x TYPE A, 1 x TYPE C) USB 3.1 PCI-E CARD + STANDARD USB PORTS
Capture/Streaming Cards
Elgato Game Capture 4K60 PRO MK.2 - PCIe Card
Windows 11 Professional 64 Bit - inc. Single Licence [MUP-00005]
Windows 11 Multi-Language Recovery Image - Supplied on USB Drive
3 Year Silver Warranty
Liquid Series® Build - Approximately 4 to 6 working days
Tubing
Coolant Colour
EK-neon green
LED Lighting
Overclocked CPU
