Legacy question - P170EM GPU Resolution
Hello. Not sure if this is the right place to post but I have an old Vortex series Laptop from 2012. It has been 'stock' until just this week when I upgraded the BIOS to Prema v2, Doubled RAM to 32GB, Installed a brand new Samsung SSD drive to replace the old Intel 520 Series, and swapped the WLAN/Wifi chip with one with Bluetooth functionality. Overall a great upgrade after 13 years of ownership!
I noticed my existing GPU (AMD 7970M 2GB) card only shows up to the maximum resolution of 1080 especially on 4k external monitors. Is there any recommendations out there where I can install a GPU card that supports external monitor resolution to 1440 or 2180? Do I also need to upgrade the existing Heatsink?
Laptops aren't upgradeable in the way desktops are, so you can't just fit a GPU upgrade I'm afraid.
Not sure thats true. Seeing I updated the BIOS from stock 1.00.04 to Prema V2, I believe I now have the ability to swap out the existing GPU card for a more powerful one. Im not too fussed about upgrading to a powerful card, I just want an upgraded card that is capable of handling resolutions beyond 1080 for everyday tasks (i.e content creation, office tasks) as opposed to playing games. I do not use my LCD display panel which is permanently limited to 1080 FHD. I always use dual 4k external monitors but in my case both screens are limited to 1080 due to the AMD GPU card installed on the chassis.
I have the P170EM service manual in my possession which includes instructions on how to remove and install the GPU card.
That’s what I’m saying, there is no GPU available for that model that would increase resolution, doesn’t exist
Those old laptops had an MXM GPU card, but only a specific few cards were made per model.
