LED Lighting - How do I Change Colour?
TheWaryFiend
Hello there all,
I have recently bought a pc with the following motherboard:
ASUS® PRIME B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
Is anyone able to tell me how to access the BIOS and or what software I need to download to tweak the colour of the LED?
Thank you in advance!
TheWaryFiend
Hello there,
I have an led strip built around my gfx card and I was hoping someone could tell me how to change the colour?
mot isn’t my motherboard (I’ve already changed this) but the stand alone strip I ordered from pcspecialist.
if anymore info is needed please let me know.
Thank you!
Bhuna50
did this not work then:
Hello there,
Thank you!
Can you post your full specs from the order page?
TheWaryFiend
It did, but there are multiple leds! I’ll post my full specs now.
TheWaryFiend
FRACTAL FOCUS G BLACK GAMING CASE (Window)
AMD Ryzen 5 5600X Six Core CPU (3.7GHz-4.6GHz/35MB CACHE/AM4) ASUS® PRIME B550-PLUS (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
NOT REQUIRED
CORSAIR 550W TXm SERIESTM SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
PCS FrostFlow 120 Series RGB High Performance Liquid Cooler (AMD) STANDARD THERMAL PASTE FOR SUFFICIENT COOLING
50cm RGB LED Strip
ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD) 10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED)
MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FR
I have changed the ASUS motherboard lights but there’s more lighting attached to the underside of the gfx card itself.
If you install cpuz it will tell you which gpu you have?
TheWaryFiend
Thank you Spyder!
I've installed the application, which tab and info do you need specificially? The CPU tab pretty much mirrors the spec I've provided.
Let me know if you need anything else.
You’d need thundermaster for that:
