Latest Drivers (16" Defiance V RTX)
phitol
I've had my laptop a good few weeks / couple of months, and bought it with the No OS option as recommended by friends who all use PC Specialist for their laptops.
As per their suggestion, for drivers, I used https://www.clevo.com.tw/en/e-services/download/ftpOut.asp?Lmodel=P9xxEx&ltype=9&submit=+GO+ to get access to the latest hardware drivers / control center etc.
I only use it for the Control Centre and only the specialist hardware (i.e. non intel/nvidia etc), and installation has gone well, with the laptop performing nicely.,
But I still wanted to check if PC Specialist have a sanitised list or repository of up to date drivers? I just want to check there is no hidden down side (other than if it aint broke don't fixit general advice!) to downloading direct from Clevo?
Shepard
Hi Phitol,
You can find the necessary files in your customer account on our website, the section is called 'tech support' and there is a button called ' downloads'.
Select the order and the OS and should get a list of all the files and drivers.
phitol
Wow!
Thats a nice touch! Most certainly welcome and definitely a good reason to recommend this kind of company to friends!
Thanks for the info!
