Large capacity RAMšŸ¤£
Ok so I'm having a bit of a sort out as I'm having to move out of my flat shortly, and pulled an old HP PC from under the bed (this was the donor for the OS on the Berserker) took the hard drives out of it prior to taking it to the tip, and pulled this stick of memory out of curiosity, it's got 4 of these in it, so a whopping 8 GB of RAMšŸ¤£šŸ¤£šŸ¤£
JKust googled it and these are its specs:
Technical Specifications for GU342G0ALEPR692C6F1​
ManufacturerUnifosa
Manufacturer Part #GU342G0ALEPR692C6F1
Memory TypeDDR2 SDRAM
Capacity2GB
Data Transfer Rate800Mhz
Pins240 Pin
Bus TypePC-6400
Error CorrectionNon-ECC
Cycle Time5ns
CasCL6
Memory Clock200Mhz
Voltage1.8
I have annual clear-outs of my 'tech'...and each year stuff in 'box 3' goes to the skip; stuff in 'box 2' goes into 'box 3' and stuff in 'box 1' goes into 'box 2'.
If I need something I take it out so it's not in any box...so things I never use will be dumped after about 3 years...but 'box 3' is more like 'attic' at the moment.
This which was the precursor to the Berserker by about 2 years is sat under the dining table šŸ˜‚
And before anything makes any comment it was before I knew better šŸ˜‚
PCS CYCLONE GAMING CASE (Red LED Fans)
IntelĀ® Coreā„¢ i7 Six Core Processor i7-8700 (3.2GHz) 12MB Cache
ASUSĀ® PRIME Z370-P II: ATX, LGA1151, USB 3.1, SATA 6GBs
16GB Corsair VENGEANCE DDR4 2400MHz (2 x 8GB)
120GB ADATA SU650 2.5" SSD, SATA 6 Gb (520MB/R, 320MB/W)
External DVD/BLU-RAY Drive
CORSAIR 450W VS SERIESā„¢ VS-450 POWER SUPPLY
CoolerMaster Hyper 212X (120mm) Fan CPU Cooler
FREE 30 Day Trial of Microsoft 365Ā® (Operating System Required)
BullGuardā„¢ Internet Security - Free 90 Day License inc. Gamer Mode
Firefoxā„¢
I haven't got any embarrassing PCs to share unfortunately, as I've had Macs since 1990-ish.
Although I'm not anti-Windows, it's just what I was paid to work with in the commercial DTP sector (starting with Aldus Pagemaker, then Quark Express, Aldus Freehand, Adobe Illustrator, Adobe Indesign, etc.) doing magazine layouts, catalogues, graphic design, posters, marketing materials, annual reports, etc.
Plus there was also the expectation from some projects to offer the same level of design but only using their limited software packages...i.e. Microsoft Office or Lotus Smartsuite.
ManufacturerUnifosa
Capacity2GB
Pins240 Pin
Bus TypePC-6400
Cycle Time5ns
CasCL6
Memory Clock200Mhz
Voltage1.8
8GB of RAM? What on Earth are you planning to do with so much memory? Cause Armaggeddon? Travel through Time? šŸ˜±
Bhuna50
Firefoxā„¢
Youā€™ve come a long way ā€œyoungā€ padawan. Trust the buildā€¦
