Hey guys,
I had a lot of bad experience with DELL in the past - the casing on all laptops I had would start falling appart after 6-12 months, with hinges being the worst.
DELL's customer support was always useless blaiming me for dropping the laptops (which I never did) or saying that tear and wear is not covered by warranty, while the problem was universall for a lot of customers due to poor build quality. The customer support would on purpose drag all conversions as long as possible so customers would just give up.
I would like to avoid that for the next laptop I buy.
How do you find "Extreme Gaming" laptops surviving 12+ months of use: do hinges fail, or plastic starts to break?
How reasonable is PCS support: if hinges on a laptop would fail after 6 months without any fault of mine, would they cover it? Or if they would charge me for repair, would the price be reasonable (DELL requested a fortune - I had to buy parts on ebay and fix it myself).
Is there specific base models to avoid? Is there any base models with metal/aluminium cases.
