Laptop Vortex II-17 build
gorsmi
Anything you would have done differently? I will be using this for business, not gaming.
I haven't spec'd anti virus software, as I already use Eset Smart Security.
Vortex II-17: 17.3" Full HD LED Backlit 16:9 Widescreen (1920x1080) Super Clear Glossy
Intel® Core™i7 Quad Core Mobile Processor Extreme i7-2920XM (2.50GHz) 8MB Cache
16GB SAMSUNG 1333MHz SODIMM DDR3 MEMORY (4 x 4GB)
2.0GB nVIDIA® GeForce® GTX 485M - DirectX® 11 (17.3" Vortex II)
250GB INTEL® 510 SERIES SSD, SATA 6 Gb/s (upto 500MB/sR | 315MB/sW)
750GB WD SCORPIO BLACK WD7500BPKT, SATA 3 Gb/s, 16MB CACHE (7200 rpm)
SONY BD-5730S 6x BLURAY WRITER & CYBERLINK SOFTWARE (£108)
GIGABIT LAN & KILLER™ 1102 WIRELESS 802.11N - IDEAL FOR ONLINE GAMING
2 x USB 3.0 PORTS + 2 x USB 2.0 PORTS AS STANDARD
Vortex Series 8 Cell Lithium Ion Battery (3,800 mAh)
Power Lead & Adaptor
1 x UK Power Lead & 220W AC Adaptor
Genuine Windows 7 Ultimate 64 Bit - inc DVD & Licence (£146)
Microsoft® Office Pro 2010 (Incl Disc & 1 License for 2 devices) (£339)
Mouse
Insurance
3 Year Gold Warranty (2 Year Collect & Return, 2 Year Parts, 3 Year Labour) (£69)
Data Recovery
2 x Hard Drive Data Recovery Service - Protect 2 Hard Drives Against Failure (£60)
Price: £3,367.00 including VAT and delivery.
Flucky
Woah, did you just scroll down every option and click the last one :p ?
If it's just for business (even if you were going to use it for gaming) drop the KILLER card down to the Ultimate.
Other than that... this is my dream machine.
Wow are you sure this is not for gaming it looks like you have set everything to the max with that Nvidia Geforce 485M and 16GB RAM and that GIGABIT LAN & KILLER Card! Agreed you don't need that card unless you do plan on gaming im curious though just what type of business do you need it for?
Teaz
quite the overkill especially for a business laptop lol. If the laptop will be handling thousands of data then 8gb of ram would do fine along with the cpu but the gpu could be droped down to the 470. same goes for the Lan killer card and go for the ultimate instead. i think the cpu is possibly fine to hold onto since they cant aren't upgradable and it should last a fair longer as advancements go by.
