Hello All,
I am building up to order the spec below, and I have a couple of questions;
1) Is there any reason why the maximum amount of 5600mHz Corsair Ram is 32gB, whereas slower ram permits 64gB?
2) This laptop comes with a 280w ‘brick’ power supply. The connector looks like one of the many generic concentric power jacks. I was wondering if it possible to charge/power the computer through one of the USB-C ports (albeit more slowly, of course)? If not, does anyone have the specs of the power supply & connector so I can investigate a possible spare?
3) Also does anyone know if the FHD-IR webcam supports Windows Hello?
Ionico Series: 15.3" Matte QHD+ 240Hz sRGB 100% LED Widescreen (2560x1600)
Intel® Core™ i9 24 Core Processor 14900HX (5.8GHz Turbo)
64GB Corsair 5200MHz SODIMM DDR5 (2 x 32GB)
NVIDIA® GeForce® RTX 4070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
4TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450MB/R, 6900MB/W)
AC Adaptor
1 x 280W AC Adaptor
Ionico Battery 99WH
PHASE CHANGE THERMAL PAD COOLING (PTM7950)
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6E AX211 (2.4 Gbps) + BT 5.3
1 x THUNDERBOLT 4 + 1 x USB 3.2 (TYPE C) + 3 x USB 3.2
IONICO 15 SERIES RGB BACKLIT UK KEYBOARD
Chassis
TongFang GM5IX7A (8GB RTX-4070, i9-14900HX, 240Hz QHD)
AC Adaptor
1 x 280W AC Adaptor
Ionico Battery 99WH
Chassis
