Laptop guidance
liverpoolchety__
Hello, I have ordered the setup shown below. Will be using it mainly for video editing and sometimes gaming. I have seen some people Complaining about the heating of PCS laptops so I would be glad to hear your thoughts on this setup.
Thank you!
Optimus Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
AMD Ryzen™ 7 Eight Core Processor 4800H (2.9GHz, 4.2GHz Turbo)
32GB Corsair 2666MHz SODIMM DDR4 (2 x 16GB)
NVIDIA® GeForce® RTX 2060 - 6.0GB GDDR6 Video RAM - DirectX® 12.1
AC Adaptor
1 x 180W AC Adaptor
Optimus Series Integrated 46WH Lithium Ion Battery
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX201 (2.4 Gbps) + BT 5.0
OPTIMUS SERIES RGB BACKLIT UK KEYBOARD
NO RECOVERY MEDIA REQUIRED
INTEGRATED 1MP HD WEBCAM
Welcome Book
liverpoolchety__
Nothing inherently wrong with it...should do the job you need it to. I would definitely upgrade the thermal paste to the Arctic paste.
Not sure which laptops have been mentioned around here for cooling so may be worth looking in the relevant section of the forum. Might be worth also investing in a cooling pad to help things
Do you see difference in thermal pastes at all?
liverpoolchety__
Well, like most other things, the better the paste the better a job it does...it's a bit like the oil for a car...sure you can buy a cheap oil and it will do a job but you will likely need to replace it more often whereas a better oil will last longer and do a better job as it has a better chemical balance and so sticks to the parts it should a bit better. That's the way I understand it anyway....ultimately getting the better paste can't do any harm and, even if it is only 5% better, it's still worth it in a laptop where little bit helps
Yeah, explained like that it does make sense. Because when you check in google there are a lot of different opinions. I do not know if i can change my order now i will check. If not, i have got Arctic mx4 at home so i will change it myself then. Thank you!
You can make changes from your online account any time up until it’s in building.
liverpoolchety__
Found it, however i am a bit confused, do i have to pay extra £16 to amend my order and another £9 for the paste?
EDIT:
Just realized that there was automatically choosen storage drive! Sorry for the spam.
