Hi, I have tried to do a search for this but a I am getting nowhere slowly so thought I would post here (hopefully the right place).
I have just sold my old iMac for £700 and am looking to replace it with a laptop for general use with a bit of Adobe Premiere, Photoshop and After effects thrown in. I have not played games much in recent years but I would like to be able to take it back up as bit of a 'light hobby'.
I have a budget of basically what I got back from my mac, and maybe another £100 or so. I am very aware that this will be a budget machine for this money and expectations are in line with this.
One thing I am having particular trouble getting my head round is the different graphics cards.
Within my budget there seems to be a choice between the Nvidia Geforce GTX 765M, 850M and possibly 860M depending on what machine I go for.
I don't really know that much about what makes one graphics card better than the other. I believe the 8 series are newer but while the 765M and 860M run DDR5 VRAM the 850M is DDR3. The 765M also runs on a wider bus 256 vs 128 (I think), but I don't really know how all of this actually affects the performance and/or begins to separate the cards from one another?
If anyone can begin to shed some light on what the differences are between these cards, and where it is best to put the £'s into or if there is something I should be avoiding then I would be very grateful.
Many thanks in advance for any help.
(Confused), Ed
(Confused), Ed
