Laptop for professional designer / animator
TomBus
Hello,
I need a laptop for when I work out of the office...
I'll be working exclusively in adobe creative suite. 50% Photoshop, 50% AE! Very little 3d animation.
This will only be used as a secondary machine, my main PC will be used the vast majority of the time.
what do you think of the laptop spec? Budget is 1.5k-3k GBP. Anywhere I'm throwing money away or anywhere I should spend a bit more for better performance?
Thanks so much!
Recoil Series: 17" Matte QHD 240Hz sRGB 100% LED Widescreen (2560x1600)
Intel® Core™ i9 14 Core Processor 12900H (5.0GHz Turbo)
64GB Corsair 4800MHz SODIMM DDR5 (2 x 32GB)
NVIDIA® GeForce® RTX 3080 Ti - 16.0GB GDDR6 Video RAM - DirectX® 12.1
AC Adaptor
1 x 330W AC Adaptor
Recoil Series Integrated 99WH Lithium Ion Battery
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6E AX210 (2.4 Gbps) + BT 5.3
1 x THUNDERBOLT 4 PORT + 3 x USB 3.2 PORTS
RECOIL 17 SERIES RGB BACKLIT UK KEYBOARD
Microsoft® Edge
Monitor
PCS PM151 15.6" Full HD IPS Portable Monitor
INTEGRATED 1MP HD WEBCAM
Chassis
TongFang GM7AG8N (16GB RTX-3080 Ti, i9-12900H, 240Hz WQXGA, Blank KB)
Price: £2,752.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/recoil-VI-17/6ESwchPDZb/
Ekans2011
Hello,
what do you think of the laptop spec? and how does it compare to the other spec underneath. Anywhere I'm throwing money away or anywhere I should spend a bit more for better performance?
Thanks so much!
AC Adaptor
1 x 330W AC Adaptor
Microsoft® Edge
Monitor
Chassis
OTHER SPEC
Technical specifications for LENOVO Yoga Pro 9 16" Laptop - Intel® Core™ i9, 1 TB SSD, Blue​
Performance​
Graphics card
- NVIDIA RTX 4070
- 8 GB GDDR6
RAM
64 GB LPDDR5 (6400 MHz)
Processor
- Intel® Core™ i9-13905H Processor
- 14-core
- P-cores: 5.4 GHz
- E-cores: 4.1 GHz
- 24 MB cache
Storage
1 TB SSD
Screen​
Resolution
3.2K 3200 x 2000p
Screen size
16"
Screen features
- 165 Hz refresh rate
- PureSight Pro MiniLED
- 1200 nits
- Delta E<1
- 100% sRGB
- 100% P3
- 100% Adobe RGB
- Dolby Vision
- TÜV Low Blue Light & Eyesafe Certification
Screen type
Mini LED
Touchscreen
Yes
Connectivity​
WiFi
- AX WiFi 6E
- 2x2
Ethernet
No
Bluetooth
Bluetooth 5.1
Ports
- USB 3.2 Type-A x 2
- Thunderbolt 4 x 1
- HDMI 2.0 x 1
- 3.5 mm jack x 1
Media​
Disc drive
No
Memory card reader
4-in-1
Features​
Keyboard
Backlit membrane keyboard with numeric keypad
Mouse / trackpad
Multi-touch trackpad with gesture control
Camera
- 5 MP IR webcam
- Compatible with Windows Hello
Security features
- Facial recognition
- Privacy shutter
Power​
Battery type
4-cell Lithium-polymer
Battery life
Up to 6 hours
Sound​
Audio software
Dolby Atmos
Speakers
- 6 speakers
- Smart AMP
General​
Colour
Tidal teal
Weight
2.23 kg
Software
* Full version of Microsoft Office not included
* Full version of anti-virus / internet security not included
Dimensions
18.1 x 362.4 x 245 mm (H x W x D)
Manufacturer’s guarantee
1 year
Box contents
- Lenovo Yoga Pro 9 16" Laptop (83BY000BUK)
- AC power adapter
- Warranty document
- Quick start guide
Hi, the Recoil model that was posted is from 2022, and I would not buy it today.
We can't comment on the other specs because it's not a PCS system.
How much do you want to spend on the laptop?
TomBus
Thanks for responding. 1.5k - 3k absolute max. Hadn't realised it was 2022 but specs still look good, no?
Ekans2011
Not at that price, for sure. :LOL:
In my opinion, you should only consider models from 2024.
There are two better alternatives available here: 15'' and 17''.
EDIT: If you need a stronger GPU (4080/4090 only available on RECOIL), you must add an external liquid cooler to achieve peak performance.
I'd add @Tron1982, who is very good on laptops. :)
1) IONICO 15''
Ionico Series: 15.3" Matte QHD 240Hz sRGB 100% LED Widescreen (2560x1600)
Intel® Core™ i9 24 Core Processor 14900HX (5.8GHz Turbo)
64GB Corsair 5200MHz SODIMM DDR5 (2 x 32GB)
NVIDIA® GeForce® RTX 4070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
4TB CORSAIR CORE XT MP600 NVMe PCIe M.2 SSD (up to 5000 MB/R, 4400 MB/W)
AC Adaptor
1 x 280W AC Adaptor
Ionico Battery 99WH
GIGABIT LAN & WIRELESS INTEL® Wi-Fi 6E AX211 (2.4 Gbps) + BT 5.3
1 x THUNDERBOLT 4 + 1 x USB 3.2 (TYPE C) + 3 x USB 3.2
IONICO 15 SERIES RGB BACKLIT UK KEYBOARD
Firefox™
INTEGRATED IR+FHD Hybrid Webcam
Dead Pixel Guarantee
Chassis
TongFang GM5IX7A (8GB RTX-4070, i9-14900HX, 240Hz QHD)
Price: £2,232.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/ionico-IV-15/DaYaBhc9cr/
2) RECOIL 17''
AC Adaptor
1 x 280W AC Adaptor
Firefox™
Chassis
TongFang GM7IX7N (8GB RTX-4070, i9-14900HX, 240Hz QHD)
Price: £2,293.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/recoil-VIII-17/eE0SBw4Gaj/
TomBus
1) IONICO 15''
AC Adaptor
1 x 280W AC Adaptor
Ionico Battery 99WH
Firefox™
Chassis
2) RECOIL 17''
AC Adaptor
1 x 280W AC Adaptor
Firefox™
Chassis
Thanks so much! I had originally thought the 4070 was overkill for a laptop due to the limited power? For mostly 2d animations, a 3080 would be sufficient? Seeing your suggestions, I'm not so sure anymore!
@Tron1982 any input from yourself would be greatly appreciated 🙏
Tron1982
Hello, sorry for the delay, i'm a little busy nowadays.
So, from what i know from my sister that doing 2D animation you don't really need a 3080ti, that is an hotter, more powerful, and expensive GPU than a 4070.
From what i saw on pcs, the best chassis right now is the 17" recoil because it has the best screen, ram and cpu. It's a little bit overkill, but I think it will last you for some time.
What proposed @Ekans2011 was almost spot on, but i tweaked it a little :
- I selected the ssd from samsung, because i have the same inside my laptop, but the other choice are good too, it's a matter of personnal preference
- I selected 32g of ram, less memory but a better speed (my sister never used the whole 32go, but it will depend what kind of size your file have, if you need 64, go for it ^^)
- I added the external monitor, as it was from your original spec, but I don't know how good it will be ^^"
32GB Corsair 5600MHz SODIMM DDR5 (2 x 16GB)
1TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450MB/R, 6900MB/W)
4TB SAMSUNG 990 PRO M.2, PCIe 4.0 NVMe (up to 7450MB/R, 6900MB/W)
AC Adaptor
1 x 280W AC Adaptor
Firefox™
Monitor
Chassis
Price: £2,421.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/recoil-VIII-17/G3fdaeBF35/
Sorry, I have an important interview Thursday, so, if you need a better answer, could you please wait until then ?
TomBus
AC Adaptor
1 x 280W AC Adaptor
Firefox™
Monitor
Chassis
Thanks! Unless you have more to add (post interview), this is perfect. I'll proceed with the purchase in the next week so if you think of anything, let me know :)
Good luck tomorrow and thanks again mate.
Have you considered using the PC remotely via a laptop? You could access the PC remotely and pass all the grunt work to the desktop rather than the laptop.
I have a gaming laptop that I rarely use now as I can always just offload any work to my desktop, gaming included (I stream remotely and locally where network permits).
The only limitation would be in offline environments when you couldn't remote in.
Tron1982
Hello,
I don't really have anything to add if you don't have any question ^^
But you may consider the solution @Scott proposed ^^
TomBus
Interesting suggestion!!
few questions - is there minimum spec the laptop would need to be or would it literally just act as a portal to my powerful home pc? I like this solution a lot, actually. Would it operate seamlessly? So no stuttering or delays when I try and perform a task. As over time that would be very frustrating. Now I'm considering saving all the money that was going on a high-end GPU / Processor / RAM and instead just focusing on having a decent lightweight laptop with a good screen. Are there any minimum requirements for this option to work well?
No minimum requirements at all that I've ever stumbled across. I can do it through my phone, tablet, lightweight work-style laptops and I even stream to Firesticks (4k and non-4k versions).
All you're doing is sending video image data and cursor/keyboard inputs, it doesn't take a lot of horsepower to process.
I would recommend still getting something decent in the laptop department, you just don't need to go over the top. For a good experience you typically need 20mb/s. I think most domestic internet would cover this. I've gamed over mobile hotspot in the past, it was absolutely fine.
You're not going to be hitting the heights on a first person shooter, as there is going to be some sort of delay no matter what you do.... but for actually working remotely it's perfect. You don't need 120fps and instant responses for working. Anything around 60fps would be more than adequate.
It would be worthwhile trialling it before you buy. I'm sure you'll have access to a laptop you could try? download Sunshine on your PC and download Moonlight onto the laptop. There's a tiny bit of configuration but it's quite easy to do. This will give you full power from the CPU and GPU, where remote desktop kind of disables the GPU in some situations.
