Graeme1873
Hi
I am thinking of purchasing a new laptop to replace the desktop I bought 5 years ago from PCS and which is starting to show its age. Also I no longer really have the room for the desktop and all that it entails.
My main use will be flight simming using FSX with high end addons but will,also use it for work on an ad hoc basis. Portability is not a great factor in my decision as it will sit on my dining table for the most part.
Budget is max £1100.
Are you able to suggest a spec that fits with my needs?
Many thanks
Donald
Many thanks
Donald
