Laptop for a Student
I am buying a new laptop for my son. He has been suffering with a HP pavilion for two years and it is criminally slow. I have promised him a big improvement. He will mainly use it for Browsing, Office applications, streaming music and videos.
He does not play 3D games.
If anyone can have a look at the specs below and advise if they believe that these will be reasonably fast I would really appreciate it. One of them has a video card. If he is not gaming or video/photo editing will this make much difference to the performance?
If you have any suggestions for improvements these will be most welcome as well
Spec 1
UltraNote: 15.6" Matte HD LED Backlit Widescreen (1366x768)
Intel® Core™i5 Dual Core Mobile Processor i5-4340M (2.90GHz) 3MB
8GB KINGSTON SODIMM DDR3 1600MHz (1 x 8GB)
INTEL® HD GRAPHICS MEDIA ACCELERATOR 4600
1st Hard Disk
250GB Samsung 850 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
UltraNote Series: 8x SATA DVD±R/RW/Dual Layer (+ 24x CD-RW)
GIGABIT LAN & WIRELESS 802.11N CARD INC. BLUETOOTH 3.0
Spec 2
Cosmos Series: 15.6" Matte HD LED 16:9 Widescreen (1366x768)
NVIDIA® GeForce® GT 940M - 2.0GB DDR3 Video RAM - DirectX® 12
1st Hard Disk
The first one, no need to get a dedicated GPU for the uses you indicated and it should offer better battery life.
SlimCini
KC and the Sunshine BANNED
They both will perform exactly the same. Same cpu, same ssd, same ram.
There are a few good value laptops in the review section with i5s and ssd's so I'd recommend checking those out before you press 'buy'.
