Lafite spec
VicD
I'd be grateful if someone could look over my spec with regards to the SSD as I haven't put a 1st hard disk -- do I need one or will the SSD alone be okay? I've got an Optimus at the moment but I need something a bit more mobile with a quieter fan.
Lafité Series: Aluminium Chassis: 13.3" Matte Full HD IPS LED (1920 x 1080)
Intel® Core™ i7 Dual Core Processor i7-7500U (2.70GHz, 3.5GHz Turbo)
16GB Corsair 2133MHz SODIMM DDR4 (1 x 16GB)
INTEL® HD GRAPHICS 620 - 1.7GB Max DDR4 Video RAM - DirectX® 12
1st Hard Disk
NOT REQUIRED
M.2 SSD Drive
500GB SAMSUNG 960 EVO M.2, PCIe NVMe (up to 3200MB/R, 1900MB/W)
FREE Assassin's Creed: Origins with select SAMSUNG NVMe SSDs!
AC Adaptor
1 x Lafité Series 40W AC Adaptor
Bluetooth & Wireless
GIGABIT LAN & WIRELESS INTEL® AC-8265 M.2 (867Mbps, 802.11AC) +BT 4.0
3 x USB 3.0 PORTS AS STANDARD
Lafité Series 3 Cell Lithium Ion Battery (36WH)
Looks good. You don't need an HDD, unless the 500gb SSD isn't large enough for your needs. You could look at a 256gb PM961 SSD, and if you need more storage an HDD too. This might make it a bit cheaper.
VicD
Thanks, Oussebon! The storage shouldn't be a problem - I've had my Optimus for 4ish years and I've got 204 free out of 459.
