Kingston HyperX 240GB SSD upgrade bundle kit?
jonbam
Hi
I'm thinking of getting a new Kingston HyperX 240GB SSD drive to replace my old 120GB Kingston HyperX SSD drive.
At the moment I'm using 57GB for the windows7 & other software I use the most.
If I choose the upgrade option on the pcs site, can you confirm what I'll get with the Kingston HyperX 240GB SSD drive?
I have seen on youtube, you get an SSD enclosure, usb & sata cable & cloning software?
Can PCS confirm whats included with the upgrade kit.
Has anyone used the cloning software with the Kingston SSD enclosure?
Bundle kit includes:, HyperX SSD, hard drive cloning software, windows 7 driver, installation guide CD, 2.5" to 3.5" , enclosure with accompanying USB to mini usb cable and multipurpose screwdriver.
thanks
Jonathan
mantadog
Superhero Level Poster
You would be best to call PCS directly or perhaps drop them an email as only they will know for sure. If I was to say one way or the other it would only be a guess as they might have the upgrade kit for customers upgrading I just don't know.
