Keyboard problem on Recoil series.
tobias840
Hi there, I own a recoil series, sometime ago my backlit keyboard has completely stopped working. Every now and then, it will turn on once I start my computer. Does any one know what keyboards were fitted in those models and or a part number for spare part ? Also what may cause this use ? Thanks 🙏
Could you copy and paste the specs but remember to remove your windows license key, you don't want that public!
If you raise it with PCS, the keyboard is part of the chassis, it's not user replaceable, you have to replace the whole of the top of the chassis.
barlew
This is a very unfortunate trend of modern laptops and I'm not sure why manufacturers have gone this way.
The cynical side of me does wonder whether or not its a ploy to get more money out of the consumer in case of repair, as pioneered by everyone's favourite tech company, Apple.
tobias840
Bump. Just before warranty was to expire back in April,I’ve sent the laptop away for RMA, it came back apparently there was no issues found(possible loose Ribon or driver issues). PCS also done a nice clean up and to top up a stress test and so on. Since then I probably used it like 10 times and the issue is back…. Keyboard is not working at all, no backlight and it goes straight to BIOS.
Lols, you never responded! Still need the full specs from your order page please
tobias840
My bad.
Recoil Series: 15.6" Matte Full HD IPS 144Hz 72% NTSC LED Widescreen (1920x1080)
Intel® Core™ i7 Six Core Processor 8750H (2.2GHz, 4.1GHz Turbo)
16GB Corsair 2400MHz SODIMM DDR4 (2 x 8GB)
NVIDIA® GeForce® GTX 1060 - 6.0GB GDDR5 Video RAM - DirectX® 12.1
250GB WD Black™ SN750 M.2 NVMe SSD (up to 3100MB/s R | 1600MB/s W)
1TB SERIAL ATA II 2.5" HARD DRIVE WITH 8MB CACHE (5,400rpm)
Integrated 2 in 1 Memory Card Reader (SD, MMC)
AC Adaptor
1 x 180W AC Adaptor
Recoil II Series 46WH Lithium Ion Battery
PER-KEY RGB BACKLIT UK MECHANICAL KEYBOARD
Windows 10 Home 64 Bit - inc. Single Licence []
Microsoft® Edge
INTEGRATED 1MP HD WEBCAM
Insurance
Welcome Book
So it would be control center that governs the RGB, is that installed?
What do you mean it goes straight to BIOS? Is that when you boot it? Does it have any error message?
Just to confirm are you using the windows 11 control center or still using the windows 10 version?
Just to be certain, can you post the chassis model number from the label on the underside of the laptop?
tobias840
Yes,it goes straight to BIOS after being turned on. No errors, no issues in the device manager… I’m using windows 11, all updates from Microsoft are up to date.
tobias840
As above, are you using the original windows 10 version of control center or the updated windows 11 version? It may have been called Gaming Center on that old a chassis?
tobias840
At the moment I’m using a original version of windows 11, however a separate license instead of the version provided by PCS. However the issue started while the laptop had an updated win 11 from PCS, as that’s what they left after it came back from RMA.
tobias840
I’m in the process of downloading win 11 provided by PCS, as it has the “gaming centre/control centre” merged within. We’ll see if that makes any difference, however I doubt that.
So yeah, not windows, not talking about that, it's a master driver that needs to be installed on the laptop and governs most things including the RGB on the keyboard. It's called control center or sometime gaming center. It will be in running programs.
Have you reinstalled windows or reset windows since you returned it to PCS?
tobias840
Yep, I’ve done it after the keyboard stopped working.
