Just need clarification!
Sammcl
Hello everyone.. So basically I have just recieved my pc from pcspecialist as of yesterday. Long story short I've seen around forums elsewhere that having a gpu temp below 90c means your all good. However I'd just like a pro's advice on this, I play far cry 3 on ultra settings, v sync 2 frames & anti aliasing x 4. Gpu average temp is 78.6c, should I be worried or not? It's a nvidea gtx 660 ti 2gb btw!
Thanks!
I wouldn't worry. You could try to increase the fan speed in your gpu but the temperatures you are recording are nothing to worry about.
tom_gr7
Life Serving
I'd say that is a tad high, but it is an ok temp, so dont worry.
not sure of your spec, but you could try adding a bottom or side intake fan to get some cool air to the 660ti.
