Just checking...
Josh
K guys, just decided to speck out a computer and came up with this:
COOLERMASTER HAF 912 PLUS MID TOWER GAMING CASE
Overclocked CPU
OVERCLOCKED AMD PHENOM II X6 1090T (3.20GHz @ MAX 3.80GHz)
ASUS® CROSSHAIR IV FORMULA: DDR3, USB 3.0, SATA 6.0Gb/s, R.O GAMERS
8GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz (2 x 4GB KIT)
2GB AMD RADEON™ HD6970 - 2 DVI,HDMI,2 mDP - DX® 11, Eyefinity 4 Capable
2nd Graphics Card
640GB WD CAVIAR BLACK WD6402AAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
2nd DVD/BLU-RAY Drive
NONE
NONE
CORSAIR 1200W PRO SERIES GOLD (AX1200) 80+ MODULAR PSU (£206)
COOLIT ECO A.L.C (ADVANCED LIQUID COOLER) (£49)
ARCTIC COOLING MX-3 HIGH THERMAL CONDUCTIVITY COMPOUND (£9)
Bigfoot Killer 2100 PCI-E Gigabit LAN Card - Max Performance Online Gaming (£67)
Comes out at around £1600
This other speck comes out at the same price but mainly the difference is, it is using a quad Intel core (what is the difference between 6 and 4, is it cache size?) and there is NVIDIA cards instead of ATI.
Here is the other spec for comparison:
Overclocked CPU
Overclocked Intel® Core™i5-2500k Quad Core (3.30GHz @ max 4.60GHz)
ASUS® P8P67 PRO (NEW REV 3.0): USB 3.0/SATA 6Gb/s, CrossFireX™ & SLI
8GB KINGSTON HYPER-X T1 DUAL-DDR3 2133MHz, X.M.P (4 x 2GB KIT)
1.25GB NVIDIA GEFORCE GTX 570 - 2 DVI,mHDMI - DX® 11, 3D Vision Ready
2nd Graphics Card
NONE
CORSAIR 850W TX SERIES (TX850) 80+ ULTRA QUIET PSU (£99)
Sound Blaster® Audigy™ SE (£19)
If anyone could be of any assistance in either making suggestions to a better build it would be much appreciated, as currently i am quite puzzled.
P.S. Sorry Gorman for re posting an already asked question about the cards.
bg92
Expert
I would go for something like this
COOLERMASTER CM690 MKII ADVANCED CASE
Overclocked CPU
1.5GB NVIDIA GEFORCE GTX 580 - 2 DVI,mHDMI - DX® 11, 3D Vision Ready
Free Item
FREE Need For Speed™ World Starter Pack with any Nvidia® GTS450 or above!
120GB INTEL® 510 SERIES SSD, SATA 6 Gb/s (upto 450MB/sR | 210MB/sW)
CORSAIR 1000W PRO SERIES (HX1000) 80+ MODULAR PSU (£169)
Price: £1,594.00 including VAT and delivery.
Configure Here: http://www.pcspecialist.co.uk/computers/intel-1155-overclocked/
Josh
Whats the difference between the i5 and i7 apart from the clock speeds? also does network cards make much of a difference, just read a review on the killer 2100 and it said it was crap so i agree with you on taking that out.
pengipete
Rising Star
There are more differences than the clock speed - there's a nice, clear description at http://www.brighthub.com/computing/hardware/articles/48391.aspx The biggest difference with the newer Sandy Bridge i's is that the i7's support Hyperthreading and the i5's don't. That's not a big deal for most people - hyperthreading is currently only significant for a few specific applications (mainly high-end video editing) and these new i's are incredibly powerful without it. Basically, Hyperthreading is one of those things where if you have to ask, you don't need it.
At present, there's no real reason to go for anything other than the i5 - superb CPU.
bg92
Expert
The network card will make almost no difference, so its useless, the difference in performance is not big between the i7-2600k and the i5-2500k, the i7 has got hypethreading and the i5 doesn't, but that doesn't make much difference, so you should be fine with i5.
btw what are you going to be using the pc for?
Josh
Pretty much purely high end gaming, games like AION with online play. But i was thinking of getting into a bit of video editing, but only using programs such as song vegas, so nothing too hardcore. :D Also i want to overclock a lot of my components, but the spec says i only need an 800W supply should i get a 1000W if i am overclocking?
bg92
Expert
For gaming the i5 should be fine, but if your are planing to have 2 gtx580 in sli at a later date and overclocking then having a 1000w psu would be a good idea,
