Hi guys, I'm trying to configure a top end, powerful gaming PC for games coming out on 2012 such as Battlefield 3 and Elder Scrolls: Skyrim. I think I have most of the components sorted, but I have a few questions -
First, will my cooling system be enough? I want my computer to be cool and quiet, so I've tried to pick a case with a lot of large fans to reduce noise and temperature, and Im hoping my processor cooling will be enough.
Secondly, is my case ok? I'm not sure if it's big enough for all the components to fit and have good airflow to stop any buildups of heat
Lastly, the power supply - I chose one over 1000W because I plan on adding an extra Geforce 580 GPU in the future, but on the website it isn't listed as branded - does anyone know if it's a good power unit, not an unbranded unreliable one? I would choose the corsair one but it's more expensive and isn't quiet.
Thanks, Josh
NZXT PHANTOM WHITE GAMING CASE
Intel® Core™i7-2600k Quad Core (3.40GHz, 8MB Cache) + HD Graphics
ASUS® P8Z68-V: USB 3.0, SATA 6GBs, NVIDIA®SLI™, ATI®CrossFireX
3GB NVIDIA GEFORCE GTX 580 - 2 DVI, HDMI, DP - 3D Vision Ready
1010W Quiet 80 PLUS Quad Rail PSU + 120mm Case Fan (£99)
Thanks, Josh
