Hello guys,
I've decided that I want to get the NZXT H1 Case. I'm trying to think of a configuration that will allow me to play / edit videos / or even stream in a comfortable way :
Processor : AMD Ryzen 7 3700X
Motherboard : ROG Strix X570-I Gaming Format Mini ITX
Graphics Card : GIGABYTE RTX 2060 SUPER WindForce OC 8G
Memory : HyperX Fury 16GB 3200MHz DDR4 CL15 DIMM (Kit of 2) 1Rx8 Black XMP Desktop Memory HX432C16FB3K2/16
Disk : Crucial P1 1TB 3D NAND NVMe PCIe M.2 SSD - CT1000P1SSD8
Case : NZXT H1
Do you think it can do the work? Or do you see room for improvement? (either put a few more $$ on a component in order to have a significant improvement, or opt for a lower version because the difference is not significant).
PS: I'm using mostly WiFi for Internet (no Ethernet) and I'm aware (if i understood everything correctly) that the front USB-C port won't work (as the motherboard doesn't have a thread for it)
Thank you in advance for your help
Case : NZXT H1
