UndeadJack
Master Poster
Anybody know how to remedy an itunes install instaloop? 3rd attempt at install and it loops. This is on my old athlon XP computer which used to have itunes 10.3
try using some of them speedup programs, it may help, http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html?tag=rb_content;main that is the best one, would download CCleaner and Auslogics Disk Defrag as well, the optimize tool on the defrag works really well, when i first did it on my old laptop got probably a 10% speed increase with access times
try gamebooster as well, that will stop unnecessary programs from running freeing up CPU power and RAM
why dont you, open it up, clean out the fans, then overclock it a bit? it may be able to cope at 2GHz or something im not sure, would be good to get some experience as well, although you may be without a computer for a while...
