So it's about that time where I get myself a present of a new PC - my current machine still works fine, but I want new stuff
Anyways, this is the spec I've got so far:
CORSAIR CRYSTAL SERIES 570X RGB GAMING CASE
Overclocked CPU
Overclocked Intel® Core™ i7-9700K Eight Core (3.60GHz @ up to 5.0GHz)
ASUS® TUF Z370-PLUS GAMING II: ATX, LGA1151, USB 3.1, SATA 6GBs - RGB Ready
NOT REQUIRED
NOT REQUIRED
NO RECOVERY MEDIA REQUIRED
Price: £1,137.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/intel-z370-overclocked/uer6HnGeVY/
So points to note:
So yeah, any comments would be much appreciated - I've become a little out of the loop with hardware over the last year so I may be behind the times with some choices
Overclocked CPU
NOT REQUIRED
NOT REQUIRED
So points to note:
- 1. I need clockspeed - the game I normally play (Everquest2 - it's an old MMORPG) relies heavily on clockspeed - doesn't care one bit about multiple cores or anything else - it entirely needs clockspeed - my current machines is OC'd to 4.5, the i7-9700k can hopefully get to 5Ghz which should show a nice improvement - apparently its runs really nicely at 5Ghz according to what I read on either their forums, the general chat channel or guild chat in game.
- 2. I'll be transferring my GTX1070 over from my current machine as I don't think the 2070 is worth 500quid over the 1070 - may wait til the next generation of GPU's
- 3. I also use the Rift VR headset for VR gaming, so need many many USB ports - I have a PCI USB expansion card in my current machine, that will move over as well, though I might need to replace it as it was being a bit weird - though to be honest the Rift has many USB related issues so it may have just been that.
- 4. Given point 3 I need enough ummph for VR games (I also need a bigger house but that will have to wait)
- 5. The review I was reading for the case is here: https://www.tweaktown.com/reviews/7...-rgb-tempered-glass-chassis-review/index.html, and I think this is the case I've decided on, but not 100% sure yet.
- 6. The Corsair H115i water cooler doesn't seem to fit in many cases (at least not ones that aren't humungous that I haven't got space for), so hopefully the H100X will be fine.
- 7. I have 2 mechanical HDD's that will be being moved over, and maybe one SSD (depends what I decide to do with the old PC)
- 8. I have an MSDN subscription so will be using Win 10 Pro
- 9. Motherboard: um, no idea - any advice on this is definitely welcome.
- 10. Budget - around this amount, give or take.
- 11. Am using 2 monitors (one is 1440p 60Hz, the other is 1080p 60 Hz) or my VR headset. I would use 3 monitors but that would require my house to be about 2 foot longer which isn't really an option!
