I bough this PC a few years back and now with the recent games i am having FPS issues like in overwatch and some games i can't but be cause the PC cannot simply handle it. I was thinking of replacing the ram and the graphics card on this PC, and was wondering whether with the 8GB Radeon RX 580, would it be compatible with this PC or if not can you recommend another one in the ATI range.
Jay
Case COOLERMASTER CM690 MKII ADVANCED CASE + 2 FRONT USB
Processor (CPU) AMD PHENOM II X4 965 (3.40GHz/8MB CACHE/AM3) - BLACK EDITION
Motherboard ASUS® M4A87TD/USB3: DUAL DDR3,SATA 6.0GB/s, USB 3.0
Memory (RAM) 4GB CORSAIR XMS3 DUAL-DDR3 1600MHz (2 x 2GB KIT)
Change to: 4GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz (2 x 2GB KIT)
Graphics Card 1GB ATI RADEON™ HD 5770 PCI EXPRESS - DirectX® 11
1st Hard Disk 640GB WD CAVIAR GREEN WD6400AARS, SATA 3 Gb/s, 64MB CACHE
DVD/BLU-RAY Drive 24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Power Supply 450W Quiet 80 PLUS Dual Rail PSU + 120mm Case Fan (£29)
Processor Cooling STANDARD AMD CPU COOLER
Operating System Genuine Windows 7 Home Premium 64 Bit - inc DVD & Licence (£79)
Jay
