mum_im_hungry
Hello all! I'm looking to purchase an affordable gaming PC for my son.
Does this look like an ok spec? He plays Roblox, Fortnite, etc.
He uses OBS and stop motion animation software to upload clips to YouTube (this will not be heavy usage like a proper YouTuber, more just as and when).
When I go through the screens on PCspecialist, it says something about USB C not being available. I do understand that USB C is for phones etc and the generic USB is probably already included. Please bear with me, I have looked at hundreds of specs in the last few months, and we've gone from just going to buy a tower from a large online retailer (bog standard £499 one which I know will plug in and work even if Fortnite has to go on medium settings) to getting a much more decent one like below). I would MUCH rather get one from PCspecialist as I know it will be far superior.
(The current pc he has was bought from a small company online that rips out Dells and adds stuff in (16GB 1TB etc- it did work fine, tiny bit laggy, had it 8 years, bought for £340). I did that because I had to buy 3 x PC's for all my children. Also, our internet speed is 240mbps and they are using a dongle into the back of the tower. It is ok but not great. Should I get a better Wifi part put in to the new PC? I'm learning the spec and options fast- but I do need to purchase one soon as his PC has overheated. Also, can I purchase the monitor separately from PCSpecialist at a later date? (He has a Dell monitor, it's ok but I want to get the PC first and get it going before I choose). Thanks very much!
PCS AEGIS BLACK ARGB MID TOWER CASE
Promotional Item
AMD Ryzen 5 7500F Six Core CPU (3.7GHz-5.0GHz/38MB CACHE/AM5)
ASUS® PRIME A620M-K (mATX, AM5, DDR5, PCIe 4.0)
16GB PCS PRO DDR5 4800MHz CL40 (1 x 16GB)
4GB MSI GEFORCE GT 1030 OC - HDMI, DP
1TB PCS PCIe M.2 SSD (3500 MB/R, 3200 MB/W)
CORSAIR 550W CX SERIES™ CX-550 POWER SUPPLY
LED Lighting
2 x 35cm Corsair LS350 Aurora RGB Light Strips
ONBOARD 2.5Gbe LAN PORT
WIRELESS INTEL® Wi-Fi 6E AX210 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
Welcome Book
PCSpecialist Welcome Book
Price: £696.00 including VAT and Delivery
Promotional Item
LED Lighting
Welcome Book
