Is this a reasonable build?
gsw_ldn
Budget: £2200
Uses case: 1440p gaming 4k or 1440p, 60hz gaming. (I have a 4k 60hz non-gaming monitor Dell 32 4K USB-C Hub Monitor - P3222QE, haven't decided if I will upgrade in the future. The 60hz frequency and 8ms average response time is not ideal for gaming, but I need the 4k for productivity.)
Any suggestion on the spec below is appreciated!
be quiet! SHADOW BASE 800 FX GAMING CASE
Promotional Item
AMD Ryzen 7 9700X Eight Core CPU (3.8GHz-5.5GHz/40MB CACHE/AM5)
ASUS® TUF GAMING B850-PLUS WIFI (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
32GB Corsair VENGEANCE DDR5 6000MHz CL40 (2 x 16GB)
16GB GIGABYTE RADEON™ RX 9070 XT GAMING OC - 2 x HDMI, 2 x DP
CORSAIR ICUE LINK TITAN 280 RX RGB HIGH PERFORMANCE CPU COOLER
ONBOARD 2.5Gbe LAN PORT
US International/USA - US English Language
Monitor Cables
1.8M GOLD PLATED V2.1 Certified HDMI CABLE
Price: £2,207.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/Qcn5p8Kdk0/
Ekans2011
Uses case: 1440p gaming. (I have a 4k 60hz non-gaming monitor, haven't decided if I will upgrade in the future. The 60hz frequency and 8ms average response time is not ideal for gaming, but I need the 4k for productivity.)
I'm confused: if the use case is 1440p gaming, why do you need a 4K productivity monitor?
Anyway, regardless of resolution or GPU, the 60Hz refresh rate will cap your FPS at 60.
gsw_ldn
Sorry for not being clear in the post. I got this monitor a few years ago for work and would like to continue using it (with another laptop). Now I'm trying to build a gaming PC with the said budget, ideally sharing the same monitor. I had an assumption that a PC that can handle 1440p gaming comfortably can also work with this monitor, given resolution is higher and frequency is capped at 60hz, which might be ok for some games that don't require super high FPS. I understand the monitor might be the bottleneck here so might upgrade it later.
Ekans2011
1440p is not a simple downscale from 4k. Reduce to 1080p would be significantly better on the monitor than 1440p.
Anyway, that monitor isn't suitable for gaming, and 60fps isn't an acceptable frame rate in 2025.
svemin
I would change the CPU to 12 or 16 core ryzen, even if not x3d version. Also, I would buy the 9070 XT externally as PCS appear to be charging around £800 for it, which is obscene, you can have one for £100-150 less from other places (or get the 5070 Ti for about the same money). I would also go with 1000W PSU just in case and take just 1TB fast SSD as primary drive and keep it clean (and add on slower, second 4Tb SSD for games etc). Finally, I would buy Windows 11 home externally
Not legally, only from grey markets which are stolen keys
Non-X3D versions will hurt your gaming performance. The only way to get the best gaming performance AND the best productivity performance is with a 9950X3D CPU as it has the same 3d v-cache as the 9800X3D, but with an extra 8 cores for productivity.
The 12-core 9900X3D has less 3D v-cache on it's 6 X3D cores, so is slower than a 8-core 9800X3D in games.
Don't forget that if you buy Windows externally, then you will have to reinstall it on the PC as the test build that it will come with is incomplete and WILL cause issues. You may also have to rely on other forums for software support.
svemin
- I disagree on non x3d versions - while x3d versions are better for games indeed, you need cores for productivity. The best would be to get 16 core x3d, this would be great for everything, but is expensive. The compromise is 12 cores x3d ot 16 cores non-x3d in the same price range.
Ekans2011
{Text has been removed]
Ehm, no. They are selling keys which can stop working anytime
Microsoft says at https://www.microsoft.com/en-us/howtotell/Shop....
Beware of Product Keys Sold Separately
With the exception of Product Key Cards (PKC’s) distributed with COA’s, Microsoft does not distribute products keys as standalone products. If you see a listing on an auction site, online classified ad, or other online page advertising product keys for sale, it’s a good indication that the keys are likely stolen or counterfeit. If you were to purchase and use a stolen or counterfeit product key to activate Windows installed on your PC, the key may not work for activation, may already be in use on another PC, or it might be blocked from use later by Microsoft when the key is reported stolen.
- I also disagree on non x3d versions - while x3d versions are better for games indeed, you need cores for productivity. The best would be to get 16 core x3d, this would be great for everything, but is expensive. The compromise is 12 cores x3d ot 16 cores non-x3d in the same price range.
OP doesn't need a productivity PC.
quote
unquote
{Text removed]
Lols, thanks for taking the time to actually go through the link.
WhoKeys are not legit, they deal in stolen keys
Just because it’s ok with you to buy compromised products doesn’t mean it’s ok for the general public and certainly not this forum
Its also against forum rules to discuss any warez on here as was clearly highlighted in the thread you so kindly ignored
svemin
quote
unquote
- No, I've bought 8 Win 11 keys and 5 MS office keys from them the last 5 years and they all work just fine
svemin
quote
unquote
In the first paragraph, the OP says they need 4k for productivity, maybe read the post fully
Ekans2011
Even though I am not a native speaker, I believe I have read better in this situation. :ROFLMAO:
quote
unquote
svemin
quote
unquote
Whether you're a native speaker or not is irrelevant, you need to read fully and pay attention to what you read
Quote
Budget: £2200
Unquote
Ekans2011
Quote
Budget: £2200
Unquote
He's talking about the monitor, not the PC. :rolleyes:
That is why I asked him to clarify the system's purpose.
ROFL Pot calling kettle black perhaps after you’ve entirely ignored anything we’ve attempted to educate you on and doubling down on false information???
svemin
You haven't said a single thing that's worth being part of anyone's education on anything really! But this is a pointless discussion, the person is free to spend their money on whatever they like however they like, what is important for them is to know that they have options, which now they know they have
Rakk
The Awesome
As a reminder there is to be ZERO discussions about cheap Windows keys - its its likely piracy or some other dodgy thing going on, so absolutely NO promoting of such sites!
And dammit, now I have to go delete everywhere in this thread that its been mentioned specifically (and I was about to go out!!!!) -
Edit: if I deleted anything that wasn't related to the dodgy sites, sorry, but it was a mess to work out what needed to stay and what needed to go, and yeah I'm about to go out :)
