Is there anything i should change
Craig R H
COOLERMASTER CM690 III ADVANCED CASE (GREEN)
Overclocked CPU
Overclocked Intel® Six Core i7-5820K (3.3GHz @ MAX 4.4GHz)
Gigabyte X99 Gaming 5P: E-ATX, LG2011-3, USB 3.0, SATA 6GBs, XFIRE/SLI
16GB KINGSTON HYPER-X PREDATOR QUAD-DDR4 3000MHz X.M.P (2 x 8GB)
6GB NVIDIA GEFORCE GTX 980 Ti - DVI, HDMI, 3 DP
1st Hard Disk
120GB KINGSTON HYPERX SAVAGE SSD, SATA 6 Gb/s (upto 560MB/sR | 360MB/sW)
2TB 3.5" SEAGATE SSHD, SATA 6Gb/s 7200 RPM (64MB + 8GB SSD CACHE)
CORSAIR 750W CS SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Corsair H100i GTX Hydro Cooler w/Akasa Apache Black Ultra Quiet Fans
Fan Controller
NZXT Sentry 3 Fan Controller with upto 5 Fitted Case Fans
1x 120mm Apache Black Quiet Fan (fitted to extract from rear/roof)
LED Lighting
60cm Green LED Strip - To Compliment The Colours of Your Case
Windows 10 Upgrade
FREE Upgrade to Windows 10 with all Windows 7 & Windows 8.1 Purchases*
DVD Recovery Media
Windows 10 (64-bit) DVD with paper sleeve
PCS EXTRA-CARE DIAMOND DELIVERY - MON-FRI, PRE-NOON
Rakk
The Awesome
If you could let us know what you'll be using the PC for and what your budget is then people can give useful comments and perhaps suggest changes
